Old 06-20-2018, 06:25 PM   #1
tdishon
59 Apache/C6 Corvette build
So I have built a few resto-mods in the past and just sold my twin turbo & supercharged Grand National and am ready to move on to my next project that will be my passion. As I'm getting older I have been really loving old trucks... So I thought I would spends a couple years building a 59 Chevy Apache with all Corvette C6 Grand Sport and ZR1 components.
I live in Arizona and sourced a good body.
[IMG][/IMG]
tdishon is offline   Reply With Quote
Old 06-21-2018, 12:17 AM   #2
tdishon
Re: 59 Apache/C6 Corvette build
Progressive Automotive chassis. Took about six months. Just getting this thread up to speed. I have been reading alot of other builds and getting help from many of you, but just needed to get pictures on Photobucket and posted.
Old 06-21-2018, 11:41 AM   #3
tdishon
Unboxed and cradles installed
Old 06-23-2018, 08:42 PM   #4
slammed57
slammed57's Avatar
NICE!!!!! frame, those boys over a progressive do some nice work
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 06-24-2018, 12:41 AM   #5
tdishon
Everything installed and new motor mounts made. Set engine back about 2" so the blower pulley would clear the rack. Torque tube still too short.
Old 06-24-2018, 12:45 AM   #6
tdishon
Engine mounts fabbed up and installed.
Old 06-24-2018, 03:27 AM   #7
Nut Case
Nut Case's Avatar
Apache
This looks like more fun than is good for crazy boogers like us...
I'm in.....
Nut Case
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 06-24-2018, 06:43 AM   #8
Greenlee
Greenlee's Avatar
Wow. This is going to be nice! Sweet build!
I’m curious how that air compressor behind the truck is working for you. I have the exact same one and it leaks oil really bad. I can’t figure out where it’s comong from. I ended up putting a pan under it so it doesn’t mess up my garage floor and I have to add oil every time I use it. Lol
Greenlee is offline   Reply With Quote
Old 06-24-2018, 11:01 PM   #9
tdishon
The air compressor is going on 6 years with no issues as of yet. Where are you leaking oil from? sight glass?
Old 06-29-2018, 08:55 AM   #10
Greenlee
Greenlee's Avatar
I bought mine around 2009 from Home Depot if I remember correctly. It started leaking a couple of years ago. It doesn’t get that much use. I took all the plastic housing off and wiped everything down, but still haven’t been able to figure out where it’s coming from. Hopefully, I haven’t jinxed yours now!
Old 06-29-2018, 08:57 AM   #11
Greenlee
Greenlee's Avatar
The dash looks killer!
Old 06-29-2018, 11:01 AM   #12
tdishon
I do use it all the time. It might be due for a leak. Lol
QUOTE=Greenlee;8291107]I bought mine around 2009 from Home Depot if I remember correctly. It started leaking a couple of years ago. It doesn’t get that much use. I took all the plastic housing off and wiped everything down, but still haven’t been able to figure out where it’s coming from. Hopefully, I haven’t jinxed yours now! [/QUOTE]
Old 06-24-2018, 11:06 PM   #13
tdishon
Gamel Street rods extended the torque tube and did a new larger drive shaft with ZR1 couplers. I have been getting the pics uploaded to get this up to date. The thread is almost current.
Old 06-25-2018, 12:44 AM   #14
Scottish58chev
Nice work, loving the chassis
Scottish58chev is offline   Reply With Quote
Old 06-25-2018, 07:08 PM   #15
MIKESAD50
Nice like the chassis and drivetrain
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 06-26-2018, 12:40 PM   #16
tdishon
Cutting out the old dash and putting in the 59 Impala dash. It was about 4" too wide. decided to take it out of the middle to line up the steering column with the factory location(hole in the floor).
Old 06-29-2018, 08:02 PM   #17
idbeast
tdishon, can I buy the glovebox portion of your 59 Apache dash, I'm doing a double din stereo and the glovebox portion of the dash would save me a lot of fab work (don't need the glovebox door).
Jim
idbeast is offline   Reply With Quote
Old 06-29-2018, 08:35 PM   #18
tdishon
The truck started out as a GMC. The dash is a GMC. Not sure it it’s the same glove box.
QUOTE=idbeast;8291415]tdishon, can I buy the glovebox portion of your 59 Apache dash, I'm doing a double din stereo and the glovebox portion of the dash would save me a lot of fab work (don't need the glovebox door).
Jim[/QUOTE]
Old 06-30-2018, 12:23 AM   #19
idbeast
Bummer, I just ran out and looked at my 55 2nd GMC and it is different... but thanks for getting back to me!
Jim
Old 06-30-2018, 04:47 AM   #20
Nut Case
Nut Case's Avatar
TD
Strong work!!!!! Using C-6 suspension, this is going to be fun to follow.
Are staying stock with leaf/shocks? Or?
Keep on keeping on
NC
Old 06-26-2018, 12:55 PM   #21
tdishon
Moved dash forward about 2 more inches to give me more room. It looked better where I had it, but it was a little too close. This feels perfect.
Old 06-27-2018, 05:34 PM   #22
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Cool build! Dash work looks familiar!!
ChuckDriver is offline   Reply With Quote
Old 06-27-2018, 06:28 PM   #23
tdishon
Hey Chuck, you did inspire the dash for sure!
Old 07-02-2018, 01:48 PM   #24
tdishon
Black_Sheep: Dash looks right at home in that pic!
Old 07-02-2018, 01:50 PM   #25
tdishon
Nut Case: I'm going to attempt to use the Grand Sport leaf springs I have from the donor Corvette. The spring rates are within 10lbs of what Progressive recommended for the coilovers. I have the coilovers as a backup. We shall see when it finally drives. It will be any easy swap if needed.
