Retro fitment of modern seat belts to our cabs
Simple really, we know it gets done.
What is the feeling out there and and who,has fitted them, took photos and want to share please. Advice on strength, fitting, welding and even sources of best options. Thank you in advance.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
Re: Retro fitment of modern seat belts to our cabs
Hi Rian
Have a look at tips and tricks section at www.lugnutz65chevystepside.weebly.com shows everything you need for 3 point install, good to see you back working on your truck Michael |
#3 | |
Need to source a set of red belts now ![]()
#4 | |
![]() Join Date: Jan 2015
#5 | |
If it I still a problem, for them to post to the USA, I could beep by being a UK delivery address. Ebay link https://www.ebay.co.uk/itm/RED-Unive...19.m1438.l2649
Junior Member
![]() Join Date: May 2016
I installed two 3-point (driver,passenger) and one lap belt (center) in my '63 and they work great. I don't have any pictures of them installed unfortunately and everything is torn back apart now. I did not weld them as the kit I bought is bolt in with proper backing plates. My belts were ordered from Julianos. They have a ton of colors and options.
Edit: I used the 90 degree bracket for the driver side, but I had to order a 60 degree bracket from Jegs for the passenger side floor mount. |
#7 | |
#8 | |
Good advice above from everyone. This is an easy upgrade I highly recommend you do!
292 + TKO500 |
#9 | |
292 + TKO500 |
![]() Join Date: Jan 2011
I used these guys when I did the three point install in mine. Have held up great and work well over time. http://www.andoauto.com/
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#11 | |
Brett | 1966 K20 - 292/SM420/T221 |
I used belts from https://www.seatbeltplanet.com/ when I had my '65 Nova. They were really knowledgeable, and very easy to deal with. There wasn't a specific kit available for that car, so I just gave them a call, and they took care of everything. The price was pretty reasonable too.
-Chris |
I got as far as drilling the holes and installing the nuts up in the cab corners. Then I decided the seat had to go and the replacement had the built in belts.
