07-09-2018, 08:48 PM | #1 |
chassis specs
I am looking for specs on a 86 chassis, are the specs the same from 73 -87 or did they make any changes ? A I can find is specs for 73-80 not sure if they are the same as 86.
Thanks for any and all help
1955 2nd on 86 chassis Daily driver |
07-10-2018, 12:54 PM | #2 |
Re: chassis specs
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
07-10-2018, 09:11 PM | #3 |
Re: chassis specs
I found specs for an 84 chassis and none of the front end dimensions match my chassis which is suppose to be and 86. I don't have any pics of my chassis to post but I did post specs for the 84.
Can anyone confirm any of the dimensions from cross member to front of frame. Also are these dimensions suppose to be the same for 73-87?
07-11-2018, 02:30 PM | #4 | |
Re: chassis specs
You will also need to check apples to apples in terms of model type; that is, compare a C10 to a C10, or a K20 to a K20, etc. K
