Radiator question
Hi folks:
I'm installing a new engine in my truck C10 69 350 engine and I need your help where can I find a new radiator 4 row. I saw some aluminum on ebay and amazon but I/m not sureb if they fit. Thanks for your help. |
#2 | |
![]() Join Date: Jul 2015
Re: Radiator question
If you still have your old one, it can be rebuilt. I have mine done for about 4 benjamins. I love that thing. All brass and copper. |
What’s your budget like? Most of the cheap aluminum radiators are just that, cheap. Stay away from Griffen, they are epoxy welded and leak like a sieve. I run a Holley frostbite and I’ve been pleased with it. I’ve also heard good things about the champion aluminum radiators. I believe Arizona performance sells them. I’m sure someone with a champion will chime in (Andy maybe?)
I bought a 2 row from cold case for my truck. Pretty much a stock 350ci. My Chevelle I have a DeWitts HP series made in Michigan its also a two row with twin fans and I'm running a Mark Jones big block with 650 hp. Never gets hot . By a good brand. Why do you need a 4 row?
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
Today’s 2 rows have more cooling capacity than the old 4 rows. With aluminum they can make each row larger.
Moderator
![]() Join Date: May 2007
I have champion in both my 68 and 72, very pleased with them.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Jsu wondering if you had your heater cores rebuilt ot replaced or left them as they were in the trucks.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#9 | |
Moderator
![]() OP, glad you have a new radiator on the way! Post up a pic when it arrives ![]()
If you install any kind of new rad and do not change out or rebuild the heater core it becomes the weak link and in all likelyhood an untouched original will start leaking very soon after the the new rad is installed.
Thanks folks:
1.-I stiil have the old one. = I could rebuilt it (is brass made) 2.-Holley frostbite 3.-Champion aluminum radiators. With this choices now I'm starting to look at the websites and if is possible to find it locally in San Diego. Budget? well I saw one for about 4 grands and a half brass an cooper and its in my budget but with your advice I want to make the right choice. I already spent a lot a money building the engine and I know is very importan to have a good cooling system. In case I decided for Champion I want to ask LEDZPP if He is using 2, 3 or for rows? thank you again, I move to search at websites. |
Moderator
CC369 is the part number, it is a three row. Their distribution center is in Lake Elsinore if you want to save on shipping and get it at the counter.
CC369 w/fan kit. Then get your harness from board member. Way less than your 4 grand jeez.
Don't spend that kind of money on a cooling setup unless your going Baja racing or something. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
The one nice thing about your brass radiator is that it can be rebuilt. With the aluminum, when it’s done, it’s done.
#15 |
Except no-one within 200 miles of me does rebuilds anymore. I can't even get rotors cut at a machine shop anymore they can't be bothered. I'll make due with a lifetime warranty.
#16 |
Thank you LEDDZEPP: yes I saw at the website area 714 is close to me hour and a half,
All Aluminum Champion Radiator 3-Row Core | Cools up to 800hp Radiator Dimensions: Total: 19.25" tall x 33.88" wide Core: 16.75" tall x 28.25" wide x 2.5" thick Inlet: 1.5" driver side Outlet: 1.75" passenger side Tanks: 2.75" thick Tubes: 0.63" thick they give a lot of info. I would like to go and see if they have a shroud for the 2 14'' fans, I already use a electric fan system. thank you so much for all you help. |
#17 |
weq92f: who's the board member sells the harnes.
#18 |
The cold case (vender here) was under 500 $ with the shroud , fans and wiring harness at the syracuse show . I did buy the early version because it was 275$ . Haven't put it in the truck yet, the original is working fine for now. Never heated up doing 75 going and coming from Carlisle in 90° heat. I bought The cold case so if the original craps the bed I have one in the shelf. The DeWitts was about 1000$ Complete. Both have lifetime warranties. Would never spend 4k on a radiator.
#19 |
gmachinz
Quality stuff built to suit your need. -klb
#20 |
Old member
3 row all tig welded aluminum CH racing is who I ordered from, Champion are any other brand though should be just fine. I have 4 of them off E bay and not one problem. All 4 of them are 3 row's. They all fit fine. It's been in the truck for 4 years and no problems. That's 2 HRPT of 6000 miles on it to, plus day driving.
My truck runs 180* while moving the fans never run. They will kick on when stopped and sitting for any amount of time. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#21 |
I run a Champion CC369, great rad and value,very well built and keeps its cool!
#22 |
Another endorsement for Champion. I've had mine in for a while now, was the last link in the chain to get the temps down on my sb400. Has performed admirably. They also come with a no questions asked lifetime warranty to the original purchaser. That's gotta be worth something right there.
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
#23 |
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
#24 | |
I tried to order the champion but the sales person said that He did not understand what I wanted I Gave him the number part but this guy was rude. That’s why I ordered the frostbite radiator from HOLLEY no shipping charge and almost same price. I will place a picture when I receive it Have a wonderful day !!! San Diego is too hot!!! Posted via Mobile Device |
#25 |
