09-20-2018, 07:19 AM | #1 |
Did GM use the same spindles for both vans and trucks?
For example, if you had a 1972 g/10 van with front disc and a 1972 c/10 also with front brakes, would the spindles be the same? I understand other parts on the suspension may be different.
Thanks for any help. |
09-20-2018, 12:33 PM | #2 |
Re: Did GM use the same spindles for both vans and trucks?
Knowing how GM does things, I’d suspect they are the same.
Maybe someone with a Hollander manual will check in.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
