Old 10-15-2018, 12:34 PM   #1
Liz
Catchy title goes here..
Liz's Avatar
What did you do to your truck today.The 3rd chapter
Chapter 2 is now complete, bring on 3. What did you do to your truck today?
Liz is offline   Reply With Quote
Old 10-15-2018, 01:47 PM   #2
tdangle
tdangle's Avatar
Re: What did you do to your truck today.The 3rd chapter
Fixed my strange temp gauge readings. I had replaced the gauge sender unit and had all sorts of strange things going on. It would peg the gauge on warmup until the thermostat opened then read mid scale which was higher then before. Driving it the readings would vary all over the place. Engine was running normal as I was checking it with a thermo gun. Ended up taking the thermostat out, drilled 2 1/8" holes in it and then filling the engine with coolant at the manifold prior to reinstalling the thermostat. Works great now. Only thing I can figure is that I had some sort of air pocket that refused to work itself out.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 10-15-2018, 02:16 PM   #3
beaterku
beaterku's Avatar
I finally sat down and starting cleaning some of the LS parts. The intake, front and rear covers were disgusting. The inside of the valve covers as well as valley covers where pretty bad too. I gave the trans the ole wire brush treatment and consolidated all of the parts in the bed.
beaterku is offline   Reply With Quote
Old 10-15-2018, 02:30 PM   #4
Indychus
Indychus's Avatar
I rolled it outside for the first time in 8 years and then test fit my headers!
Indychus is offline   Reply With Quote
Old 11-01-2018, 06:13 PM   #5
elorenzof
WOW. Just. WOW.
elorenzof is offline   Reply With Quote
Old 10-15-2018, 02:31 PM   #6
leddzepp
Moderator
leddzepp's Avatar
I drank beer and stared at it, that’s about it
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 10-15-2018, 04:06 PM   #7
nlped
nlped's Avatar
^^^I had a few beers too... But I did have a chance to clean up the TH400 out of Chubby. It's next to be sold.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 10-15-2018, 06:42 PM   #8
Colt_1911
Colt_1911's Avatar
New grill and filler caps on my 71
I had to do some modifying do to the AC, but turn out pretty sweet
Colt_1911 is offline   Reply With Quote
Old 10-15-2018, 06:49 PM   #9
samkost
samkost's Avatar
Very nice Colt,
If I may ask, what product/vendor are the fillers and particularly the filler cap over the top of the radiator?
Thanks,
Sam
samkost is offline   Reply With Quote
Old 10-15-2018, 06:57 PM   #10
FRCvette
Very nice job on cutting filler panel for a c. I am also interested in radiator cover.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 10-15-2018, 07:10 PM   #11
Colt_1911
Colt_1911's Avatar
LMC Truck for both in the black finish
Old 10-15-2018, 07:54 PM   #12
samkost
samkost's Avatar
Thanks Colt,
Sam
Old 10-15-2018, 08:41 PM   #13
OregonNed
OregonNed's Avatar
Making plans to go refuel it..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 10-15-2018, 09:08 PM   #14
CG
BlahBlahBlah
Last week I moved it from beside the shop to the front of the houses driveway and cleaned all the leaves of of it. Then I cleaned out my shop enough to get it inside. Then we had a bit of a freeze so last night I put my daily in the shop and tonight I put the GMC back beside the shop to get covered with leaves and gunk again. Poor thing .
Old 10-19-2018, 07:17 PM   #15
NoStopN
NoStopN's Avatar
It got a shout out on Twitter by GMC. https://twitter.com/GMC/status/1053304723057635330
1969 GMC 2500. 250 I6, 4-speed w/ granny low
NoStopN is offline   Reply With Quote
Old 10-19-2018, 07:51 PM   #16
Domingo
Drank beer and replaced front wheel Bearings
Domingo is offline   Reply With Quote
Old 10-19-2018, 08:30 PM   #17
Canuckvetter
How did I get this OLD!
Canuckvetter's Avatar
I added the, new to this truck, door panels, deluxe knobs and deluxe glovebox door. Slowly building a patina CST. Thanks 1rippen6 for the armrests.
http://67-72chevytrucks.com/vboard/a...1&d=1539995052
1967 Oshawa built LWB Fleetside. 327,3 OTT, 515 Vermilion, CST, PS, PB, Shoulder Harness, Tach,Vac, Speed Warning, Choke Delete, Manual Throttle, Fawn interior. Dealer installed A/C 04/2015, N34 Rosewood Wheel 06/2023
Members who I have met personally. Metaldoc, chevnkevin, 62 Longbed, 72LHorn, 72MARIO, YBNORML, TBONE1964, Classic Bowties, Chevemall, Dagnabbitt.
Canuckvetter is offline   Reply With Quote
Old 10-20-2018, 10:19 AM   #18
70STOVEBOLT
70STOVEBOLT's Avatar
Removed the doghouse and pulled the motor and trans to clean up the front third of the frame for paint.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-22-2019, 04:17 PM   #19
Dad's72
Dad's72's Avatar
How hard was it to pull the doghouse off? I have looked for detailed steps online but couldn't find anything. I need to pull mine off to put the motor and trans back in easier. And to clean things up a little. I have an 8 ft garage so the lift will not get high enough to clear the grill.
Dad's72 is offline   Reply With Quote
Old 01-22-2019, 06:35 PM   #20
72c20customcamper
72c20customcamper's Avatar
I got my upper bed moldings. They were delivered to my rental property as that's where my truck is stored. But with the ice and cold Im sitting it out next to my woodstove with a nice glass Tullamore Dew. But I'm going to Buffalo this weekend to look at a big block 68 .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-20-2018, 05:36 PM   #21
3757chevy
3757chevy's Avatar
Drove to work this afternoon. I had driven my Blazer this morning.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 10-20-2018, 06:25 PM   #22
RodnRudy
RodnRudy's Avatar
I "winterized" Old Red today. Replaced the "mags" with the ralleys and while I had the rear wheels off I replaced the brake shoes and painted the new drums I bought at Auto Zone. I've never liked the drums I got at NAPA, they were not concentric, and causing a pesky vibration. I'll finish buttoning her up tomorrow after the paint on the drums is dry and take her for a test drive.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 10-28-2018, 08:03 PM   #23
jocko
jocko's Avatar
Phil, what did you paint your drums with? When I looked at the inside of the drums, I thought the blue tape was a reflection off of "highly polished" braking surfaces... Ha. Truck looks sharp!
Old 11-05-2018, 03:22 PM   #24
RodnRudy
RodnRudy's Avatar
Jocko, sorry for the slow reply, I don't look around here too regularly. The paint I used is Eastwood Extreme Chassis Black in Satin, also used their Chassis Black Primer. It's a pretty durable epoxy. I had it left over from when I painted my frame. Thanks for the kudos on my truck.
Phil
Old 10-20-2018, 08:28 PM   #25
Andy4639
Old member
Andy4639's Avatar
Talking Re: What did you do to your truck today.The 3rd chapter
I traded some old 4 lug pony car wheels and tires for these to go on the front of my ramp truck. The guy said he bought them in 1970 and has had them on several trucks.
They aren't perfect but they are perfect for the ramp truck!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
