11-30-2018, 08:43 AM | #1 |
Weather seal between cap and body??
“They all leaked from the factory”
The words of my very good friend Dennis in St Louis who used to work for GM in the 70’s and early 80’s So I live over in England and my 79 Blazer certainly leaks as much as anything that may leak. Which means LMC and the other suppliers are not just up thr road. My question is this....... What is the consensus on what foam seal to fit between the fiberglass cap/canopy and the body? Some original GM part or use an alternative type of high density type foam to seal it from leaking ?? Thank you.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
11-30-2018, 11:56 AM | #2 | |
Re: Weather seal between cap and body??
I will investigate various options. Possibly over the weekend. Dennis used to build these for GM. His advice. I don't think you will find a aftermarket seal that will work.Even the factory ones fit like ****. Once you take the roof off you will see why it's so hard to get them to stop leaking. The main problem is getting the seal to stay in place while you get roof back on. You will need a couple of buddies to help you. It has to go down and forward at the same time while someone is inside lining the bolt holes up making sure that the gasket don't fall out I was thinking of making some kind of cross shaped carrier to then lift it all hydraulically on my own. REMEMBER THIS THING ? https://youtu.be/vfTC9wyQKK0 Will see how it all unfolds.
