12-10-2018, 02:00 AM | #1 |
1994 G20 Van spindles
I have a 1994 G20 Chevy van with a known head gasket. It’s worth more in scrap then what I could ask it for. My question is, could I use the spindles on the front of the van for a disc brake conversion. If so could I also use any aftermarket brake booster and master cylinder. I really dislike the plastic MC from the 90’s Thanks. What else could I also rip apart on the van to upgrade the truck?
Posted via Mobile Device |
12-10-2018, 02:20 PM | #2 |
Re: 1994 G20 Van spindles
I dont know about the spindles.
However, I would yank out the trans. Its most likly a 4l80E being as the donor is a 3/4 ton. A 4L60E would also be worth grabbing. Id also keep the motor if its a 350. It should be a factory roller cam motor. At the very least grab the serpentine set up and all brackets. FYI 4.3 accessory drive is the same as the 5.7 IIRC.
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
