02-11-2019, 01:52 PM | #1 |
Shifter Options
Im trying to find a suitable shifter for my truck and wondered what others have been using.
Ive installed a 454ci with a Bogg Warner Super T10 4 speed. Although my bench seat is not in its final position I reckon I need a tall shifter with a dogleg in it so I can reach it and so it clears the bench. One thing I have noticed about the short Hurst shifter thats currently in it, is that its not a bolt on fitting (Unlike the one in my Vette) it locks in place rather than bolts. I cant find anything that locks in, they all seem to bolt in and I cant find anything longer than about 16". Anyone got any suggestions on a suitable shifter? |
02-11-2019, 04:55 PM | #2 |
Re: Shifter Options
To make it theftproof you could adapt a 3 speed column to 4-speed...
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
02-12-2019, 12:10 AM | #3 |
60-66 Nut
Re: Shifter Options
I don't know about what will work with your bolt less shifter handle receiver, but those running a manual 4 speed trans such as yours, typically recommend a shifter handle for a '55-6-7 Chevy. It has a dogleg to fit around the seat.
02-12-2019, 04:17 AM | #4 | |
Re: Shifter Options
I had another look on Summits website last night and found these two options both of which I think will work: https://www.summitracing.com/int/par...iew/?rrec=true https://www.summitracing.com/int/par...iew/?rrec=true I would prefer something a little taller though. 15.5 & 16.5" is about the shortest I can get away with. Id prefer 20" and the first one is described as being available in different lengths but I cant find any options, yet! |
02-12-2019, 05:05 AM | #5 | |
Re: Shifter Options
02-12-2019, 05:41 AM | #6 | |
Re: Shifter Options
Of the 2 shifters I listed above I think the first will be best but its also the shorter of the 2. If I could get that one in say 20" it would be ideal. But if you can get a change to take a couple of pictures that would be great. |
02-14-2019, 05:21 PM | #7 |
1961 crewcab
Re: Shifter Options
this thread has some shifter talk and pics:
http://67-72chevytrucks.com/vboard/s...t=shifter+nova http://67-72chevytrucks.com/vboard/s...t=nova+shifter http://67-72chevytrucks.com/vboard/s...t=nova+shifter
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
02-15-2019, 10:48 PM | #8 |
Re: Shifter Options
So I hacked off the top of the existing shift stick, using the new one as a template I drilled and tapped the needed holes in the stub then bolted it in. I still need to clean up the stub cut off another inch and grind it clean, but saved myself $300
Mike 1960 C10 Short Step 235 w/ 3 on the tree 1999 Mazda Miata <- Track Car 2016 Chevrolet Colorado z71 2016 Chevrolet Traverse - Wifes Car 2014 Honda CBR500R <- Also A Dust Collector 2009 Suzuki GSXR600 <- Stolen |
02-16-2019, 05:58 AM | #9 |
Re: Shifter Options
I think that may very well be the best way to go with this. Like you say it save $300 (at this point thats definitely a consideration) but maybe more importantly I can increase the height of the shifter at least a couple more inches. Currently all I can get is 15.5-16.5 inch tall shifters. Id like 18-20 inch. If I go this route I can get the height and maybe even rake the shifter to the left a little to bring he shifter to a more natural position, at the moment its leans toward the right.
