02-17-2019, 05:32 PM | #1 |
Wiper Washer Hose Routing
On my 66 the washer reservoir is mounted by the voltage regulator and horn relay. I know the hose is routed along side the wire harness on the inner fender but how is it attached to the harness? Tie straps? Coiled around like the AC power feed?
Also, the AIM shows a few mounting variations on the firewall and the bag style by the heater but doesn't show the core support mounting. I can see how the optional brake power booster, (which I don't have), would be in the way. What other reason would it be mounted on the core? A 64-66 year model change? Thanks! |
02-18-2019, 01:22 PM | #2 |
Re: Wiper Washer Hose Routing
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
02-18-2019, 01:27 PM | #3 | |
02-18-2019, 02:45 PM | #4 |
Check The Champ, Demonstrator
Assuming it's a 66 Chevrolet!
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
02-18-2019, 07:06 PM | #5 |
Those are excellent diagrams, thank you! That's exactly how mine is configured. All I need is to find the three straps.
I think I will try to locate another firewall hose clip too. I only have two. The instructions for the AC system only shows two but all wiper washer related diagrams show three. |
02-18-2019, 07:14 PM | #6 |
Now I'm getting a little confused. This is what I have found so far. These straps look like the diagrams but these are made to insert into a hole.
The diagram instructions say to "use the straps provided". Since the harness already has integrated hole mounted clips I was assuming the straps shown only wrapped around the harness and just happened to be drawn in the same location as the hole clips. What do these straps actually look like? |
02-18-2019, 07:19 PM | #7 |
This is what I thought I was looking for:
02-18-2019, 08:48 PM | #8 |
Heres what originals look like. If yours was dealer installed they might be different. Ill have to check an accessory kit. This truck has 22,000 original miles , still has the original ribbed washer hose.Theres 3 of these clips
Plus theres three of these metal clips on the firewall
02-18-2019, 10:44 PM | #9 |
Cool, I have straps with that same function, not necessarily correct but they will work the same. I guess the straps as part of the wiper accessory kit were different.
In one pic I can just barely see one of the harness clips that attach to the inner fender that's next to one of the hose clips. It looks like the hose clips aren't used as designed to be inserted in a hole. Just used as a wrap. |
02-23-2019, 03:46 PM | #10 |
Just discovered something else that may or may not be related to the hose routing. I think it's harness related.
I discovered this pic of a metal harness clip on the driver's inner fender. It's right next to the hole for the integrated plastic harness clip. Not sure why it would be needed. Any ideas? |
