Old 03-03-2019, 12:32 PM   #1
Coley
Coley's Avatar
Smile 2005 Silverado-Durmax: electrical problem
Ok, I have an 2005 Silverado 2500HD with the Duramax drivetrain...a great truck overall.
However, I'm starting to have a weird electrical issue...actually there are a few, but one is a bit more annoying than the other.
First one is that now when I shut the truck off and exit it, the dash lights and radio often stay on. So one of the choices is to manually shut the radio off or dim the gauges to zero.
....but, if I go around to the passenger side and open and close the door on that side, they shut off...as they should.
I am aware that there is a 10 second delay before this stuff sometimes shuts down but that doesn't often happen...sometimes when I exit the store and come out to the truck the radio is still on, lol.
Anyone else have this happen?
the other issues have been the slow demise of initially the speedometer and then the tachometer...and the dimming of a few of the dash gauges.
This is not the problematic one tho'.
Any insight on this guys is much appreciated!!
Regards,
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 03-03-2019, 02:08 PM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: 2005 Silverado-Durmax: electrical problem
The first issue is the door switch in the drivers door. Pretty common.
The second issue is your instrument cluster. Very common on 03-07 trucks.
95 S_Trucker is offline   Reply With Quote
Old 03-03-2019, 09:06 PM   #3
hatzie
Moderator
hatzie's Avatar
The door switch is built into the latch on the GMT800 trucks just like my 2005 VW. The switches fail and you can't R&R them from the latch so you have to replace the $200 latch because of a failed $2 switch.
Get the cluster rebuilt by a competent tech. It needs six, or seven with the optional transmission temp gauge, X27 stepper motors and likely needs new lamps and cracked solder joint repairs as well. The tooling to do the repairs correctly costs more than sending it out.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-05-2019, 03:53 PM   #4
68Gold/white
http://www.youtube.com/watch?v=-Vfrw27B2nY
I just replaced 7 stepper motors in a 03 Escalade. ORdered kit from Amazon. Soldering iron, de-soldering tool, light bulbs, solder, needle removal tool, all for like $36.00. Have watched several videos. Not easy, nothing too difficult!!!
Did this yesterday!!!
68Gold/white is offline   Reply With Quote
Old 03-04-2019, 08:10 PM   #5
My 07 did that a good bit. As mentioned, the most common issues( far as I have seen/heard) is the drivers door lock switch. What I did was spray some CRC electrical spray into the latch function and it would clear the issue , for a month or 2, then I'd have to do it again. I have read that it is a plastic switch and the greases used in it drying out and causing the switch to stick.
Old 03-04-2019, 09:23 PM   #6
Coley
Coley's Avatar
Smile Re: 2005 Silverado-Durmax: electrical problem
Good info so far guys...very helpful and much appreciated.
I agree, looks like it is within that door switch...noting that I can get everything to shut down if I open and close the passenger door.
So that info on spraying it with CRC electrical spray is interesting.
I wonder if it is the switch itself that cuts out?....or is it the mechanism that trips it?...probably more than likely, and whatever that looks like.
As for the Cluster...yeah, there is a company not too far from here that specializes in redoing those. The other thing that I found out is that you have to keep with the original gauge package because it seems to be attached and directly linked to the VIN # of the truck....go figure, lol.
...first the door switch tho'. I'm wondering (and shaking) about calling the local GM dealership to find out what that switch costs, lol.
Damn new vehicles....lol
if anyone has any useful tips on accessing (removing/installing/or?) this door switch, by all means weigh in !
All Good
Coley
2000 Dodge Ram 1500
Old 03-05-2019, 04:07 PM   #7
hatzie
Moderator
hatzie's Avatar
You can DIY this but...
The foil layer is a little thin. If you aren't careful of the heat when you're desoldering the steppers you can end up with a mess in a hurry.
Lots of examples of Ham handed repairs making things much worse.
Old 03-06-2019, 05:58 PM   #8
fun in dirt
fun in dirt's Avatar
Just replaced our door latch switch in '06 Duramax dually a few weeks ago for the same issue. Fairly easy swap out; ours was on passenger side. Got it off amazon from dealership in Tx for $188.
About midnight, I was awaken by the horn blowing & alarm going off with it sitting in carport. After running outside in pj's with pistol in hand & seeing nothing around, it stopped after several seconds. Then a few days later going down road, the radio goes off & dome light comes on , like the door had opened ... only after all that did we figure out it was the latch
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
