09-18-2019, 09:50 PM | #1 |
56 straight axle squarebody hubs
Hey...need some help here.
My original idea of getting a M2 IFS from Heidts just won't materialize fast enough financially for me to wait any longer. Ive picked up my original straight axle and springs for mounting under my original frame but ive already mounted a squarebody rear end and flipped springs in the rear. Im wanting the 5x5 chevy bolt pattern so how can i manage to get the front pattern to match the back pattern with disc brakes? I looked at the hub assembly from a SB and the spindles of my 56 and they obviously wont fit onto the straight axle as the kingpins are very different lengths...but will the SB hubs fit over the spindle shaft of my 56? Or what else is available to me to make this setup happen? Also..just to confuse the issue im needing to drop the front end. I see in LMC they have 2" lowering leaf springs for the front..anybody here know what those are like? Assume its just a flatter profile and less leafs to create the drop. |
09-19-2019, 12:05 PM | #2 |
Re: 56 straight axle squarebody hubs
First of all, the SB hubs are NOT for king pins - they use ball joints at the top and bottom. Using the sb hubs (I am assuming you're wanting to swap to disc brakes) on your stock spindles would take some adapting, just like the aftermarket kits now available. Check places like Speedway, CPP, LMC, etc. to see what they offer - not sure if they have the 5x5 bolt pattern or not.
Yes the springs will have less leafs and be flatter. Do a search as there are people on here that have done that. |
09-19-2019, 10:08 PM | #3 |
09-20-2019, 11:18 AM | #4 |
We've all been there! I think at one time I had wondered about it they could be modified to work so don't feel bad. Would be nice if someone would come up with a dropped spindle to fit the stock I beam and hubs but don't know if it's even possible.
09-20-2019, 04:57 PM | #5 |
for your leafs, see if you have a local shop that does de-arching, they will have something like "spring and axle" in their name. the local shop may be cheaper than the aftermarket even with new bushings.
09-19-2019, 05:15 PM | #6 |
The normal bolt on 5 lug disc brake conversion for your straight axle uses 1970-78 Camaro rotors which are 5 on 4.75" However, Speedway carries those rotors in a 5 on 5" pattern so you're covered there.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
09-23-2019, 05:52 PM | #7 | |
i find it tough to believe that im one of the ONLY guys to ask about a conversion for my 55-59 chevy to disc brakes and a pretty std chevy truck bolt pattern..using my stock spindles so the following is the convo: Regan: So can i swap in that pattern..do you have that disc with that pattern thats not in a kit? Standalone that i can swap in in place of the 5x4.75? Speedway: That we do not have or we would offer a kit with the 5 on 5. You may want to check with Brake Tech Solutions or ECI” Brake for availability of a kit with that lug pattern. Regan: Ok..fair enough. Thx for your help. Regan: last question.. say i do buy this kit, and source a set of discs with the 5on5 pattern im looking for which wont be too difficult since every 2wd 1/2ton chevy truck in the 70s thru 80s came with that pattern,, with the bearings that come with this kit, will they fit? Speedway: Doubtful and the first obstacle would be the rotor diameter to match up with the caliper placement. Second would be where the bearings placed the rotor as far as inward or outward from the spindle. We have thought about casting a special rotor for your needs but so far haven’t had enough interest. Let me know if you come up with an 11” rotor and I can present it to the engineers for advisement. now im stuck... |
09-24-2019, 09:02 AM | #8 |
so now im thinking..
should i just buy this kit and get them re-drilled to a 5x5 pattern? this would mean every time i replace my front brake rotors id need to get this done but, that not that often i suppose or is it easier to get my rears drilled to a 5x4.75 or swap out my axles? id rather NOT do this as i have my wheel thoughts kinda set (squarebody rallyes) |
09-24-2019, 01:27 PM | #9 |
They list the rotor with the 5 on 5 pattern, it just doesn't come in the kit. You're going to have to buy each separately apparently.
Trust me, I know the kit (I make and sell disc kits for a living just not trucks) the 1970-78 Camaro rotor is listed on their site with a 5 on 5 pattern. I would buy the rotors first to make certain you get them, the kit with 5 on 4.75 is available from anyone. Don't try redrilling a rotor, normally no space and even if there is it'll crack
09-24-2019, 01:44 PM | #10 |
This is the kit, #91031916 $269.99
These are the rotors you want in 5 on 5 #91031064 $49.95ea https://www.speedwaymotors.com/1973-...Inch,1969.html Same rotor that's used in the kit but different bolt pattern for their circle track racers With part numbers in hand I guess it's worth a try to see if they would change rotors but I wouldn't hold my breath.
09-24-2019, 11:33 PM | #11 | |
Why would the guy tell me he dont have it? Doesn't he want a sale? As i stared at that kit i realized its not a power brakes kit which would explain why its so reasonably priced compared to other kits i found that were PB with the master cylinder and booster included. I did find a kit from Classic Industries for my truck with the 5on5 and PB for $949USD but i haven't pulled the trigger yet |
09-25-2019, 04:18 PM | #12 |
That speedway rotor is intended for dirt track use so there may be legal issues if you use it on the street and it fails. That would be up to you
There is a kit for 180 that has the brackets and bearing adapter but you still need the rotors and calipers Scroll down the page. http://ecihotrodbrakes.com/early_che...nversions.html Personally if I had to have disk on the I beam I'd just go with that speedway kit or a similar one and run the 5 on 4-3/4 wheels on the front and carry a dual pattern spare. You can swap 50/54 Pontiac drums and backing plates onto 47/59 Chevy 3100 spindles reasonably simply as they use the same wheel bearings. That is if you aren't bent on having disk brakes on the I beam.
09-25-2019, 06:06 PM | #13 | |
Those rotors are stronger then OEM, they have 5/8 studs instead of 7/16" The only correct way to change bolt pattern, is the way these are made drilled from the factory. No liability what so ever.
09-25-2019, 06:19 PM | #14 |
09-25-2019, 06:48 PM | #15 |
Yes because they are intended for race cars with race wheels that use 5/8 lug bolts. and lug nuts that the racing organizations require.
What I was saying though is that they are not approved for street use by the DOT of the US or Canada. That simply means if you get in a wreck and they thoroughly inspect your truck you are up a s--- creek with no paddle The "oh they are stronger " nonsense doesn't really fly then. You might want to check your wheels with a 5/8 bolt to see if one would even go though the lug bolt hole.
09-25-2019, 07:24 PM | #16 | |
DOT only regulates rotor thickness in big trucks not our trucks or cars. Original 5 on 5 used 1/2" studs the 5/8" should fit but that's a good idea to check that first. https://legalbeagle.com/6076515-dot-...uirements.html
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED Last edited by mgchevyparts; 09-25-2019 at 07:40 PM. |
09-25-2019, 09:53 PM | #17 |
Good comments on the lugs sizes..really.
Just a question here if things go south. Is it possible to just swap out my rear axles.in favour of an axle with 5x4.75 in my SB rear end? Or just move to a 6 lug pattern... |
09-28-2019, 12:35 AM | #18 |
We commonly install complete rear ends from 1955-57 Chevy car, width is perfect about an inch smaller and you just reposition and weld the spring perches to match the stock leaf springs. Yours is a 55-59 truck, right
09-28-2019, 08:51 AM | #19 |
Thats right. 56 GMC. Shortbed Step so i wanted to keep with a truck pattern an the rear end is from a 75 truck with the springs from the same. I had to reposition the hangers to fit the spring length. Took out the overload leaf and flipped the axle.
09-27-2019, 10:47 PM | #20 |
I don't know of one that will swap. You might be able to have the axles and drums redrilled for the 5 on 4-3/4 pattern but that might cost as much as using a car axle with the right bolt pattern.
09-27-2019, 11:55 PM | #21 |
Ya..i thought about that too.
I will likely spring for the 5x5 kit from Classic Parts..its pricey but probly by the time i buy some hubs that might not even work ill be close to the same cost..even if i swapped lug patterns now id have to buy new rear drums and wheels so... I appreciate the discussion fellas. |
10-09-2019, 10:07 AM | #22 |
i may just abort the 5on5. it seems like a friggin hassle ill have to do when i need to replace the front brakes anyway. i wanted teh 5on5 because thats the rims i had (kinda backwards, but had i known its not as easy to find teh right hubs ..)
i guess at this point i have 2 options for 5x4.75: 1. find a rearend from an late 70's firebird / camaro, tidy it up and slide that in 2. replace the axles and brake drums in my rebuilt (complete new brakes, axle seals and a coat of paint) SB axle (3.07 gears) |
10-09-2019, 01:13 PM | #23 | |
so looking into option 1. i have found a 10 bolt rear end housing for a "early 70's" camaro for $30. its just a shell and axle tubes, no brakes or gears or axles..just the case. will the ring and pinion from my truck RE work in there? id have to purchase the axles and brakes and seals etc, but was probably going to have to anyway... this thread has taken a turn 180 degrees. ill probably start a new one. |
10-10-2019, 01:59 PM | #24 |
Before you give up. I was researching wheel studs. Typical ARP and Moroso 5/8 studs have knurls from .660 to .685
Moroso has a 1/2" set that has .685" knurl, just might work #46490 It would be nice if Speedway could tell you what the knurl size is but I doubt it. Worst case buy one rotor and pop a stud out and measure the knurl
10-10-2019, 05:39 PM | #25 | |
