10-02-2019, 07:13 AM | #1 |
67 c10 steering help
I have a 67 with stock control arms, cpp drop spindles and 86 chevy steering gear box. My question is what needs to be done to make all of the 86 steering components work, like inner and outer tie rods and center shaft. any help would be appreciated thanks
10-02-2019, 10:11 AM | #2 | |
Re: 67 c10 steering help
If they were spec'd for 71-87, you just need to use 71-87 disc brake steering linkage parts. If they were spec'd for pre-71, you need tie rod adapters to make things work.
10-02-2019, 11:20 AM | #3 |
The spindles were for 67 and I did use new 67 ball joints. Spindle adapters? Ive never seen those I will look it up. Is the hole bigger or smaller?
10-02-2019, 03:08 PM | #4 | |
Not spindle adapters; tie rod adapters. An adapter sleeve simply allows different thread size inner/outer tie-rods to work together. It was common to use the later disc brake outer tie rods that utilize larger thread diameter vs the earlier drum brake (smaller thread) tie-rods. You can't just switch to disc brake inners & outers because the earlier drum brake truck drag-link has to fit the inners (the smaller diameter inners). Here's the info you should review. For the record, this in the FAQ section of the forum: http://67-72chevytrucks.com/vboard/s...d.php?t=444815
10-03-2019, 11:42 AM | #5 | |
10-03-2019, 02:24 PM | #6 | |
My first go @ this was back around 1988 on my 68. I swapped in Western Chassis drop spindles for a 73-87. I used 71/72 outers with 67/68 inners & the 67/68 drag link (and original manual steering box).
