10-09-2019, 08:21 PM | #1 |
Help with IDing rear diff
77 K10, trying to ID my rear diff. I can't find a plate on it anywhere and I want to make sure I can get a new gasket so I can change the fluid. Anybody recognize this? I'm pretty new to trucks, and don't know a whole lot yet. I Googled 12 bolt GM rear ends, but everything I've found says they weren't on a 77 K10
https://imgur.com/gallery/kFvn96T |
10-09-2019, 08:56 PM | #2 |
Re: Help with IDing rear diff
12 bolt truck rear diff .
skip the gasket and get a tube of RIGHT STUFF gasket maker and use it to make a decent bead . or do a gasket and some rtv on both sides . the last few diff cover gaskets i did 100% dry and clean are ozzing fluid . so i need to drain and reseal dam it . going with option one i posted above like i should have from the start .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
10-09-2019, 09:01 PM | #3 | |
10-10-2019, 06:54 PM | #4 |
I ended up pulling off the cover. It looks like it maybe has limited slip or something but I'm not positive what it is exactly. Also there's a tiny little gear deal with some broken teeth and a shaft that's all stripped. Anybody know?
https://imgur.com/gallery/UyAfXzt |
10-15-2019, 05:03 PM | #5 |
driving is in my blood
Its the oem rear on the trucks until the 80's then they switched to the 10 bolt.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
10-15-2019, 05:08 PM | #6 |
10-10-2019, 07:05 PM | #7 |
Moderator
Eaton G80 Gov Loc and it's on the way out.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
10-10-2019, 07:09 PM | #8 |
Just my luck. Do you think this is something worth trying to repair? Or should I replace the entire carrier? I'm thinking about throwing the cover back on, filling it with fluid, and forgetting about it untill I can buy myself a new one for Christmas Last edited by Dleslie212; 10-10-2019 at 07:22 PM. |
10-10-2019, 09:45 PM | #9 |
Moderator
They have a bad reputation for doing just exactly what this one did and then dropping the weights into the ring and pinion.
Right now you don't necessarily need ring and pinion gears. If you're careful and lucky it'll last til you can replace it. If you don't luck out those weights will get into the gears and make a larger mess. Get a Limited Slip Diff. It'll behave and it won't explode.
10-10-2019, 10:21 PM | #10 | |
I just read that those weights can be removed and basically turn it into an open diff, so that's probably what I'll do to buy myself some time. What are your thoughts on the Eaton TrueTrac? |
10-10-2019, 11:47 PM | #11 |
Moderator
The Yukon clutch pak LSD will react faster and more consistently. And they are less expensive.
10-11-2019, 08:53 AM | #12 |
10-11-2019, 09:46 AM | #13 |
Moderator
The 12bolt truck axle is 8.875" ring gear and the axles are 30 spline.
The 12bolt car axles could have several spline counts but the 12bolt truck used 30 spline. There are three different carrier sizes. You'll need to know what the ring & pinion ratio is...
10-11-2019, 09:52 AM | #14 | |
10-12-2019, 12:47 PM | #15 |
I have a Truetrac in the front 10 bolt on my 81 and its been flawless no issues. The only problem is for the 12 bolt (and 10 bolt), you need the 3.73 and up carrier to use.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
10-12-2019, 01:05 PM | #16 |
I thought ihe truetrac was a straight carrier replacement. Did you mean the ring gear? I don't know alot about these things sorry
10-12-2019, 01:45 PM | #17 | |
Moderator
As I noted a couple posts ago there are three carrier sizes. Eaton doesn't cover the 2.73:1 carrier and I don't see any others listed for that size either. If you have that gearset you're changing gear ratio or not putting in an LSD. You do have a choice of using an Auburn or Yukon with your rear end... not just Eaton. I've run Auburns in 3.75" Chrysler rears under a 69 Fury and two 69 Dodge Polaras. All three had built B383 engines and A833 transmissions. I was not gentle with any of them. The Auburn LSDs cured my one wheel peels and hooked up both sides near instantly under some challenging conditions and they did it without exploding. I turned propshafts into pretzels and broke ears off yokes but the rears held up just fine. https://www.justdifferentials.com/category-s/2285.htm
10-12-2019, 02:24 PM | #18 |
Moderator
Usually the gear ratio or at least the tooth count and part number is stamped on the side of the ring gear.
Just spin it around til the stamp is showing.
10-13-2019, 06:27 PM | #19 | |
Ring gear stamping https://imgur.com/gallery/ik9wO7n |
10-13-2019, 07:26 PM | #20 |
ring gear looks like 1978 made .
as to ratio that got eaten up when they cut the gear . . looks like your counting . but if i was to make a crazy shot at it from your pic and guess maybe 41/11 = 3.73 and they were common .
10-13-2019, 07:30 PM | #21 | |
What do I go about counting? How many teeth on the ring gear? Or should I just plan on replacing ring and pinion as well due to those chunks missing? |
10-13-2019, 07:44 PM | #22 | |
Moderator
You probably get to install bearings and seals in the end of the axle tubes as well. I'd look into what it would cost for a used 10 bolt or 12 bolt with the same ratio and a warranty. Pull the cover and look it over before you take it home.
10-16-2019, 12:10 PM | #23 |
Moderator
Mismatched front to rear axle ratios can and probably will do bad things to the transfer case and can foul up the transmission and/or one or both of the axles as well.
If you haven't put it in 4wd without a catastrophe you probably want to verify the front ratio. 3.73 is an optional 1/2ton axle ratio. Your SPID label in the glovebox should call out an RPO code for the axle ratio installed at the factory. GT4 is 3.73 axle gears and G80 is the Eaton Gov-Loc differential. I'd be fairly confident the axles haven't been fooled with if the SPID matches the parts installed in your rear axle... but verification never hurts. You have to pull the axle cover to change the gear oil. The G80 does bad things when used with limited slip additives so someone that knows will likely look at the SPID and assume the Eaton is still in place. If you put a limited slip diff in the axle it's a good idea to put some kind of tag on an axle cover bolt above the axle tube noting that Limited Slip Additive is now required. This is one of those "posi" tags from GM. https://www.ebay.com/i/330781133705?...d=330781133705
And please let us know if and how your repairs were successful. Last edited by hatzie; 10-16-2019 at 03:30 PM. |
10-16-2019, 12:37 PM | #24 |
The transfer case is a whole other thing... I took it out a few weeks ago and tried to pop into 4WD, but the linkage was seized which is a pretty common thing I guess. Anyway, linkage works now, but I haven’t had a chance to take it out and test it. It is a NP203 that I am 50% sure has been converted to part time. I’m going to jack it up tonight and see if I can spin the front driveshaft while it’s in gear. I’ll also look for that tag in the glove box, I wasn’t sure where the tag was supposed to be. And I’m sure I’ll end up opening the front diff at some point this weekend to take a look in there as well
