16.5 x 9.75- who's makin' tires
Who all is making tires now days for 16.5x 9.75 rims? ...10/2019
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
Re: 16.5 x 9.75- who's makin' tires
interco / super swamper there the big one anymore . very few others left out there .
the swaper market for 16.5 is decent thet have some less aggressive stuff offered .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
short answer, STA and Interco.. mostly offroad application in those sizes..
carefully consult tire specs for rim widths, bias ply/radial, and tube/tubeless.. Firestone makes a Transforce series in 16.5 but not sure if available in those widths.. there are some extreme duty military surplus variety available as well.. this will get you started, good luck! https://www.intercotire.com/tires/tire_rim_diameter/165 https://www.stausaonline.com/tire-size/12-16-5lt/ https://www.firestonetire.com/brands/transforce https://www.ebay.com/i/264461504448?
I started out with nothing - and I still have most of it |
Thanks , I was just curious if I could use them if I wanted.... I knew Interco made that size at one time and their tires are very expensive.
Was wondering about a regular comparable competitive priced tire . Not a good selection at all I got new 16x10"- 058 eagles and Toyo tires last year Are the STA tires all non Radial , Bias Ply? Looks like very expensive Interco is really the only option .
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting Last edited by GSP7; 10-10-2019 at 10:44 PM. |
Slim pickins in the 16.5s.
Just bit the bullet myself and got into the 16 x 10s as well. It was painful. Sold the 16.5 x 9s with 35 x 12.5 BFG MTs to a guy who wanted the rims for the military surplus tires.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
just a little food for thought..
you may find a 16.5 tire to your liking at lower cost than 16 due to lack of popularity.. since you have the wheels, no harm running a set of tires on them and discard it all when worn out.. poking around ebay, looks like some 16.5 less than half of similar 16 I was looking at recently.. yes, I believe STA are all bias and interco make both.. others you'll have to check.. but not all sizes available in both rim sizes so shop carefully.. good luck! for instance, these 16" superlugs are 36" diam on 16x6.5 late model wheels.. not sure that profile available in 16.5 by STA but opposite may apply to other makes.. btw those are 33x12.5x15 TSLs on the blue one and they look puny by comparison ![]() ![]()
#7 | |
Looks like the Eagle Alloy 058 are all gone, (dont make 'em anymore). . I should have bought 2 sets of 16 x 10" .
16x10 x 5" backspace. Wheel Vintiques
Are those heavy steel rims?
For aluminum , all I can find is these, that are simular to Eagle alloy 058s.... Looks like the holes are larger on the American Racings https://www.ebay.com/itm/16x10-polis...kAAOSwzXxaTmSh https://www.ebay.com/itm/16x10-baja-...EAAOSwx2dYGjko /
BlahBlahBlah
33x12.5 16.5 ... Interco/swamper/radial's yep expensive, but probably less than the crazy 24 inch tires people run on their 2 wheel drives. I don't have this truck anymore, but it rode nicely and wasn't overly noisy.
I thought the super swampers are very soft and wear out fast on the pavement?
BlahBlahBlah
It wasn't a daily. I just used it as a truck, errands in to town blah blah. So I cant really tell you how quickly they wore. My guess is I only put a couple thousand mile on them before selling the truck to another board member. And he doesn't use it as a daily either.
I had the manager of my local Firestone store tell me there was never a 16 1/2 wheel, but they could but a 16" would stretch enough to fit it!!! I quickly left that store and will never return!!!
Take Care Troy |
had guy 1 time years ago ask me to remove a 16" tire from a 16.5 rim . . . . what a mother-trucker hell job that was . . . wedged on the tapper of the 16.5 rim i got it off but it was tuff going even with a good tire machine .
#15 |
So it actually fit?!?!
Take Care Troy |
#16 |
oh it was on the rim and aired up . but man was it hard to get unwedged .
16" tire on 16.5 rim . it also was not square on the rim one hell of a wobble . and not even close to seating the beads .
