01-20-2020, 05:25 PM | #1 |
71 K20, Eaton H052
Hi folks, My 71 K20 has an open Eaton H052 rear Dif. I would like to convert it to a locker, either manual or automatic. I called Eaton and they said unofficialy I could use a Detroit Locker number 225S10. I need 30 spline axles for the Detroit. Has anybody done this conversion and know of an axle that would work? The axle shaft diameter is 1.5 in. I don't have a length. Any and all suggestions are welcome. Thanks, Jack
01-20-2020, 06:07 PM | #2 |
Re: 71 K20, Eaton H052
personally..id just get a locking 14b and swap it out...not sure on the widths though..but if possible itll be much cheaper than trying to do anything with the ho52
01-20-2020, 06:18 PM | #3 |
Thanks Greg, I'll look into it.
01-20-2020, 07:29 PM | #4 |
been told and read the detroit form a 14ff will swap inside the open carrier in place of the spider gears . then the 14ff shafts the correct length will swap over also . then you have a eaton ho with a locker .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
01-20-2020, 08:09 PM | #5 |
That would be pretty nice. Thanks for the tip.
01-20-2020, 08:50 PM | #6 |
i might be a bit off on info for the 52 .
but here is a MEGA thread on ho72 stuff https://www.pirate4x4.com/forum/chev...aton-h072.html
