02-01-2020, 09:04 AM | #1 |
Torque Converter question?
I have a stock LM1 with double hump heads, .500/.500 Cam
and a Hurricane intake with a 600 CFM Edelbrock carb. With the Hurricanes 3,000-8,000 RPM Power Range, I was wondering what the best stall option is for a TH350 with a current 1,700-2,100 Stall?
Paul '68 C10 327/TH350 LWB |
02-01-2020, 04:53 PM | #2 |
Re: Torque Converter question?
I'm not an expert on stall converters but since no one else has answered I will give it a shot. To start with you need to match the converter to you cam not the Intake. My best guess is with a 500 lift cam you will need about a 2200-2400 stall.
The weight of the vehicle and gear ratio in the rear has a lot to do with it also. A heavy vehicle can make a 2400 stall operate more like a 3000 stall. The more stall you have th he bigger gear you need in the rear. I can tell you from experience a 3600 stall will not work with a 308 gear in these trucks. So here is my thoughts on this, the bigger the cam the more stall you need. The more stall you have the bigger the gear you need in the rear. Not having anymore info than you provided and with my limited knowledge on the subject I wouldn't suggest you go more than 2400 stall. |
02-01-2020, 05:10 PM | #3 |
driving is in my blood
He's on the money. We need duration specs @.050 more then anything.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
02-01-2020, 05:23 PM | #4 |
Or call the converter manufacturer, give them the info they need , they'll tell you what you need...
But also agree with all above...you need your full cam specs...along with alot more info on the truck.. I used to run a vega convertor ( approx 2200 stall) behind a flat top 350 with 500/300 cam...worked good with 5.13 gears and t350
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 02-01-2020 at 05:28 PM. |
02-01-2020, 09:42 PM | #5 |
You'll want atleast a 2500 rpm stall to allow the engine to idle better.
We need gear ratio, and desired tire height too. These can crutch a engine with low torque, and move relatively ideal around the map. Also the cam duration is a big deal. More over lap the lower the torque, and bigger need for a high stall converter. Judging by the rpm band your in the neighborhood of 250 duration at 50 thousandths. Or roughly a duntov 3030 cam. A deep gear ratio like 5.13's are less stall sensitive then lets say 2.73's. 2.73's will get more cowbell from a loose converter the. 5.13's. Converters are fuzzy logic, and simple changes can have big effects. |
02-01-2020, 10:13 PM | #6 | |
02-02-2020, 09:14 AM | #7 |
Thank you guys! The Cam RPM range is 3,400-7,000 and I'm currently running 235/70R15 which will be replaced with something bigger eventually.
It should have the stock 3.73 rear.
02-02-2020, 01:34 PM | #8 |
02-11-2020, 09:18 AM | #9 |
Can you post the entire cam specs so we dont have guys guessing at what cam you got? Lift and RPM range isnt all we need. Take a pic of the cam card and post it.
Anthony |
Tags |
th350, torque, torque converter, trans, transmission |
