Whats compatible with a 69 C60?
Hi Gang
Recently purchased a 69 C60 wrecker and I am in the process of making up the "needed parts list". It has a non original - worked Chevy 350 engine 4 speed. My questions for now are these: What Glove box inserts fit? Exclusive to C-60's or other models? Rubber cab floor mat? " " " " Outside door handles? " " " " Heater resistor? Front fender side marker lights? " " " " What is the best place to get these type of parts? How about a new wiring harness for under dash? Ron Francis Wiring or does someone have another they had great luck with? Thanks in advance for any info! Glen Thanks for your time. Looking forward to working on this thing. |
![]() Join Date: Jun 2017
Re: Whats compatible with a 69 C60?
The cab is the same as a C10/20/30. Glove box insert is the same. I'm still waiting on a floor mat but got mine from brothers. Outside door handles I'm not 100% sure. Heater resistor I also go from brothers. Front fenders are unique to C50/C60 I'm not sure what else but a C10/20/30 will not fit. Wiring harness I believe can also be found on brothers also.
https://www.brotherstrucks.com/default.asp |
Moderator
![]() Join Date: Aug 2017
Rubber cab floor mat? " " " " They're all the same but the big trucks have a slightly different low transmission hump. They do not make c60 specific floor mats from what I can find. Hopefully pavement-pounder willblet us know how well it fits. Outside door handles? " " " " Same 68-72 Heater resistor? Same Front fender side marker lights? " " " " Same What is the best place to get these type of parts? Ebay, rockauto, good used OEM parts, Carolina classic truck. Also check out some of the vendors here instead of brothers or lmc. I've never been impressed with anything I bought from those 2 places. How about a new wiring harness for under dash? Ron Francis Wiring or does someone have another they had great luck with? Never heard of him but after looking through his website he looks legit. Most members use painless wiring kits.
Alex 1967 C50 292ci Lumber truck 1967 C50 292ci Dump truck 1967 C60 366ci Fire truck |
