Help tell me what motor I have?
Good Morning.
The only number I can find on the motor without taking the block forward is K 0 5 0 1 0 GA Can anybody read this? I was told it is a 327 but who knows |
Re: Help tell me what motor I have?
pic
'65 283 from what I found. 3spd manual car. If it's a running engine it's a good find. I'd like to find one
#4 | |
![]() Join Date: Aug 2019
They were all small journals in 65.
You are correct. My question was to confirm if it's a '65 283 or a '69 327. He mentioned bolt holes on the oil pan not lining up
Runs like a top. Just would love to know what I have.
Just dont know what it is and the oil pan is not right because the front two holes are 1/4 inch out. Bolts are not even close to going in
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
![]() Join Date: Feb 2009
I don't know 283, but If that were a 402, I'd think you mean the 1/4" bolts to the timing chain cover, which made little contact to begin with. The original bolts do not work with a one-piece gasket.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: Aug 2003
The casting number on the back of the block will give you the definitive answer.
I have tried with every light and mirror I got.
neck is toast for days can't turn it to the right lol Any tricks? One of them anal cameras be perfect right here. |
65 283 car
69 327 impalla car |
Harold Saunders would know as he is farting. miss the old boy.
I would guess and say that is a partial vin from a 4x4 k code not sure if gm used k in other vin numbers
Block casting numbers are at back top of the block To varify 327 check block casting code and also check crank casting code as well Example 350 casting code block 3970010 with a 327 casting code crank You can get either a cheap inspection camera or use cell phone to take pics of the block casting code and depending on casting number further inspection would be needed Like my bros 327 with 3970010 block casting code its a 350 block pulled the pan and checked the crank casting code next came up 327 truck crank https://nastyz28.com/sbchevy/sblock.html https://m.youtube.com/watch?v=5COyGWqJsVE https://www.mortec.com/location.htm |
#15 |
The harmonic balance or is different also. The 283 will have a thinner balancer than the 327. If you can get a picture of it that will probably help someone to let you know what you have.
#16 |
The ‘K’ is the assembly plant.
Look here for that. https://nastyz28.com/chevy-engine-code-stampings.php A 65 283 will have a road draft tube hole cast into the block. A 69 327 won’t. Road draft tube hole is beside the distributor. |
#17 |
K St Catherines, Ontario
05 May 01 1st day of the month Ga 65-283-195 HP-2BBl-3 sp manuel trans |
#18 | |
65 283 is awesome. I will try the cell phone picture trick when I can climb back up there. Thank you guys
