06-13-2020, 09:28 PM | #1 |
Motorhome Tilt Column, bolt in ready
$250 local, $300 shipped
Please respond in thread only per board rules, first "I'll take it" gets it. Selling a motorhome tilt column. From a mid 80s GM chassis I moved the NSS down so it's a bolt-in for your 67-72; I used my multi-meter to adjust it, you may need to fine tune it after install. Turn signal has no lever Turn signal switch is tight and cancels as it should Includes the cancel cam The gray illumination wire is fairly long Includes a long pigtail for the Neutral Safety/Reverse switch Tilt mechanism is tight and smooth. The 4 bolts in the tilt mechanism that typically loosen over time have been removed and reinstalled with lock-tight. Tilt pivots were cleaned and lubed when removed to tighten the bolts. The bottom bearing was cleaned and greased The upper bearings were cleaned and greased The shift indicator bulb was replaced and tested OK, it has the green shade on it. Shifter lever end (inside column) is good, pivot is average Shift arm and adjuster lever have nice chrome, they shine up well. The finish on it is OK, great for a driver. Some scratches as pictured. It would probably buff out nicely. I will include a new GMC Paul's gear indicator, pics are with the old original You will need to add your dash and firewall gaskets, as well as the firewall plate.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
06-13-2020, 09:36 PM | #2 |
Re: Motorhome Tilt Column, bolt in ready
More pics
06-14-2020, 05:39 PM | #3 |
Project Junkie! Fishing Poor!!
I'll give you 250.00 shipped. Please let me know. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
06-15-2020, 08:32 AM | #4 |
Can we meet in the middle at $275?
06-15-2020, 12:23 PM | #5 |
PM returned. Yes we can meet in the middle. WES
06-15-2020, 12:58 PM | #6 |
Sounds great
Sold to Wes
06-15-2020, 08:22 PM | #7 |
PM sent. Shipping out tomorrow.
Tags |
column, steering, tilt |
