![]() Join Date: Mar 2019
Quality extractor set. Easy outs??
Anyone have a good extractor set that they use and has held up over the years?
Need to get the socket style to get wheel cylinder bolts off the rear brake assembly. Thanks Posted via Mobile Device |
Re: Quality extractor set. Easy outs??
I have had better luck with left hand drill bits then any easy out I’ve ever tried.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
I've got the Craftsman socket style and they work great. But, if you're trying to remove a bolt with a rounded head, get a nut that is big enough to fit over it and weld it to the bolt head. The heat will make sure it comes out nice.
![]() Join Date: Jan 2021
I’ve got a snap on set works awesome.
Bad thing about any brand easy out and if you break it off as you trying to back the bolt/stud out now you have a super hard bit that you can't drill thru.
I would drill out the bolts. Nice sharp drill bit and a bit drill oil. I haven't done this but maybe just grind the heads of the bolts off assuming you aren't using the wheel cylinders again? |
I used to be a boat mechanic, so believe me when I tell you I have extracted a lot of busted bolts. I have a matco DEK10 extractor set with the left handed drill bits. It has served me well.
Pro tip: Hands down, the best oil I have ever used for removing busted bolts is Rapid-Tap If it's in a place that you can heat it up with a torch, heat the busted bolt until it's cherry red. start dropping rapid tap on the busted bolt At first it will smoke, then when it is the correct temp something magic will happen ![]() Let it cool to room temp If possible, grind, sand or file the busted shank flat use a center punch to dimple the center of the bolt before you drill. 60% of the time, it works every time. -Russ
Insert clever text here: Last edited by Greasey Harley; 04-01-2021 at 11:09 PM. |
