Flat-Out Engineering front end?
Hello...has anybody installed a Flat-Out Engineering front end under their truck? I have the set-up and just have a few questions about how the steering shaft from the column to the rack worked and whether you had to replace the steering column.
TIA |
Re: Flat-Out Engineering front end?
With any R&P set-up on a C10, you'll most likely need to adjust the column length to suit your needs.
I can't answer specifically about the Flat-Out set-up, but I had to shorten my column around 6" to have more room in the cab & get a clean, non-binding angle under the hood for a Porterbuilt set-up.
#3 | |
It's inside the rails. My steering shaft runs between the upper a-arm + C/O mount & exhaust flange (Ramhorn style manifold). Getting the shaft centered between the 2 required getting column length just right.
Thanks for the info!
![]() Join Date: Mar 2005
I have the Flat-Out Engineering front setup sitting in the bed of my 71 C10. Been looking at different peoples installs and such.
1984 K5 Blazer 4x4. Because my daily driver needs to be a project too... ![]() 1971 C10. Auto Cross/Pro Touring Build. Project : I am gonna go broke with this one. 1970 Chevy LWB 4x4. 355, 4spd, Dana 44 front, Dana 60 rear, 35x12.50 tires... STOLEN I will put a Turbo on anything with an engine if the $$$ is right. Once upon a time.... |
I looked @ Flat Outs stuff but purchased a Porterbuilt C4 Dropmember back when he made them in the early days. It's all still sitting on some shelves in the shop.
One of these days. . .....
There are some subpar photos in a few threads I found. Here is a video Link with some decent shots for the front suspension:
https://www.youtube.com/watch?v=UOzF3xNDf-8 In that video Dustin refers to the engine set back of nearly 10 inches to get the engine placement right due to the steering rack mounting location. If you look at the side shots of the truck the wheels are setback in the front wheel well towards the cab. His truck Flat work on the auto cross track. I talked to Don at Flat Out and he said the engine setback is not needed if the wheel is centered in the fender. I am building my truck for auto cross first and foremost. I will rework the steering rack situation if need be. Been a lot of times I thought I should have just built my own crossmember and used C6 or C7 Corvette front suspension components. I took the quicker way out.
#10 | |
The video looks like he is using an 84-87 C4 set-up. I am using a 95 set-up. Apparently there is no way to hook up a sway bar on the later set-up. Just curious if anybody found one that works. |
#11 | |
#12 | |
As for the Sway bar I am gonna run a Splined setup. I will make the links myself. Engine placement and steering rack setup are my biggest concerns. The again thats what the Plasma cutter and Tig welder is for.
![]() ![]() Join Date: May 2015
pretty sure you need to clock the r&p for better fitment.. somewhere i got a link on doing that with the flatout
from there itll take a couple of ujoints and a stabilizing bearing to get inline with the column..then use DD slip shaft to connect
I am not sure how they would do that with the mounting. If you can find the link, it would be appreciated.
#15 |
#16 | |
#17 |
Did a rough mock up on the tailgate of dads 72 C10 with my oldest son today. Sometimes I wish I had went with RideTech LOL.
#18 | |
Yours looks good! Do you have a rack and pinion? Apparently they are getting hard to find. |
#19 | |
From the threads and post I have found and couple guys I have talked too. Its the rack and pinion that is the biggest interference with engine placement. My truck is a cut down LWB truck. I have two other SWB frames. I don't have an issue cutting up the shortened fame to make this work. My original intention was to build a full custom frame. I just got a bit lazy... LOL
#20 | |
#21 | |
It really depends on the purpose of the truck I guess. I don't mind the harshness of hiem joints personally. I am building the truck to autocross and beat the crap out of. I will most likely setup my engine and trans on some type of temporary motor plate to make sure my engine placement suits me. The rack how it is mounted it typical of the Corvette. it sits inline with the balancer of the engine. That alone will dictate the placement of the engine setback wise. I don't want to modify the firewall if I can keep from it. Once I have the mock up engine and trans in place, I will get the crossmember fit on the wheel centerline and in the wheel well like I want it. Reworking the steering rack isn't something I am too worried about. There are plenty of options there. It would have been cheaper to order a front suspension from NoLimit or Scotts Hotrods LOL...
#22 |
When I asked Don about engine mounts for a 350 and oil pan clearance issues, he said "most guys use LS engines". From the conversation, that meant that LS engines would not have any clearance issues, but the 350 might.
I have neither of those, so it really didn't matter. |
#23 | |
#24 |
Well if someone is interested in my front suspension PM me. I think I am changing directions.
#25 |
I got a few install pics from Dustin. His truck without a doubt handles like its on rails. that is a 10" engine set back. I am sorry to say the Flat Out Engineering is on crack if they think an LS engine is gonna drop in without the engine setback an some janky drive line angle.
I still think I could make it work by reworking the whole steering setup. At this point my truck will just be a cruiser until I regroup and decide what I am going to do.
