09-09-2022, 07:25 AM | #1 |
Fan question
Hello, my 70 C10 does not have a clutch on the fan. This seems odd to me and that it could be robbing power. The engine does run nice and cool even in 100 degree weather and in traffic but I just wonder if it would be more efficient to install a clutch. Could I just buy a nice aftermarket clutch to install and would it adapt to my current fan or would I need to buy a full assembly. My dad has owned the truck since new and he said it never had a clutch. Thoughts?
09-09-2022, 07:52 AM | #2 |
Re: Fan question
09-09-2022, 11:37 AM | #3 | |
Re: Fan question
09-09-2022, 08:46 AM | #4 |
Re: Fan question
Yes, they rob power. With a clutch it will still rob power, when it's hot out.
I would add it. The clutch addition may possibly quite the cab some? The fan should be spaced so the center of the fan is at the outside edge of the shroud. Last edited by Accelo; 09-16-2022 at 09:49 AM. |
09-09-2022, 10:20 AM | #5 |
Re: Fan question
A clutch fan does relieve some load from the engine, especially at cruising speeds
If the new clutch fan is shorter overall than the current spacer, than a shorter spacer the thickness of the difference would be needed so the fan blades remain 1/2 in/out of fan shroud. Spacers are available at the typical sources, Summit, etc. Hayden is a good brand for clutch fan, They typically come with a bushing that may be needed depending on size of tip of water pump flange. Confirm specs of fan opening and hole spacing when picking the fan clutch Many went with a 7 blade fan also |
09-09-2022, 11:31 AM | #6 |
20' Daredevil (Ret)
Re: Fan question
All good info above. Clutch fans seem to have usually been spec'd with factory A/C and / or high-performance engines due at least in part to their superior cooling capability.
My K20 is running a Hayden #2747 heavy-duty fan clutch with the factory 18", 7-blade fan and it stays at normal operating temps even when it's 100+ outside with A/C on.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 09-09-2022 at 01:46 PM. Reason: added info |
09-09-2022, 01:45 PM | #7 |
20' Daredevil (Ret)
Re: Fan question
I just now watched the video -- very interesting results!
One more detail which I have posted before.... I once put an aluminum flex fan (temporarily) on my K20. That was the only time it ran hot. Went back to a clutch fan, no problems.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
09-09-2022, 02:04 PM | #8 |
Re: Fan question
well even though my little 250 6 cyl with its fixed 4 blade and no shroud to speak of (just a small top piece to supposedly keep one's hands out of moving fan) a clutch fan alone using the same 4 blade would likely yield 10 hp gain, maybe more but can't compare to the V* dyno numbers of Engine Master test...which would be the cheapest way of gaining 10hp
otherwise for me even during these 100+ days it does not run any hotter than cooler days |
09-09-2022, 10:30 PM | #9 |
Re: Fan question
I wound up using a Hayden 2705 & 6-blade Derale 17118 (18" rigid fan).
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
09-15-2022, 10:17 AM | #10 | |
Re: Fan question
With a SBC in the forward position and a long water pump, it puts the fan fully into the stock shroud. I know they say it should be half in, half out, but that doesn't seem very safe. I have no idea where the stock fan was located, but I don't have any cooling issues. |
09-15-2022, 10:37 AM | #11 | |
Re: Fan question
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
09-15-2022, 03:23 PM | #12 |
Re: Fan question
For my truck, I bought it with a flex fan (very noisy!) and went with suggestions here for a rigid fan and clutch - worked out great - stays cool even without a shroud., used the Hayden and Derale mentioned above..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
09-16-2022, 08:50 AM | #13 |
Who's got steelies?
Re: Fan question
Seems like most manual trans. trucks came from the factory with non-clutch fan, just the automatics had clutch fans.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
