03-30-2023, 07:19 PM | #1 |
Need help cross referencing pitman arm
Hello, I’m rebuilding the front suspension on my 1967 c10 2wd shortbed pickup with manual steering. I need help decoding the pitman arm casting number in my truck and cross referencing it to a modern pitman arm part number. The casting is 3889239A. Anybody know what that old part number shows up as?
03-30-2023, 07:54 PM | #2 | |
Re: Need help cross referencing pitman arm
https://www.summitracing.com/parts/mog-k6130?rrec=true |
03-30-2023, 09:13 PM | #3 |
This list may help on other parts you may need .
These are the parts I used on my 67 C-10 , Always double check part #'s before ordering . When I swapped out the manual steering and drum brakes Moog parts from rock auto 2- Moog upper ball joints - K6023 2- Moog lower ball joints - K6024 1- Moog Pitman arm - K6131 -- Power steering 1- Moog idler arm - K6096T 2- Moog lower control arm shafts - K6147 2- Moog upper control arm shafts - K 6098 2 - Moog tie rods - ES 370R 2- Moog tie rods - ES 350L 2- Moog tie rod sleeves - ES 350S From Summit Summit price matches so you can find these parts listed on Ebay and save $$ Ordering Cpp parts thru Summit gets you fast free shipping 1- Classic Performance 2.5" Drop Spindles CP4S2 ( L&R) 1- Classic Performance Upgraded Disc Conversion Rotors CP4R-6 (L&R) 2- Classic Performance Wheel Bearings CP4B 2- Dorman Axle Nuts 4993 For power steering gear I used https://shop.advanceautoparts.com/p/...omer-reviews-d With a lares coupler (rag joint) https://shop.advanceautoparts.com/p/...rm=201+coupler order online with Advance discount code and save 25 % and pick it up from your local store __________________
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
03-31-2023, 06:46 PM | #4 |
Grumpy old man, thank you for the complete list. Very helpful from someone who has been down this road!
Tags |
1967, c10, pitman arm, shortbed |
