Oil filler tube
Question for those in the know. Had my motor rebuilt about 5 years ago. The short of it they didn't replace the original valve covers and the original oil filler tube that is mounted with the original brace bolted to the intake manifold.
Does anyone know who makes reproduction of the oil tube Assembly. Any help would be appreciated. |
![]() Join Date: Jul 2003
None are reproduced. There are a few floating around.
What year do you have? 1969-70 are different than 1971-72. The earlier version twists into the valve cover and has a twist on steel cap with cork gasket. The later version sits in a grommet and has a push in rubber cap. Both are secured using a steel brace bolted to the intake manifold. 1971-72:
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels Last edited by 1970cstblazer; 10-29-2023 at 02:37 PM. |
Re: Oil filler tube
1971 350
Thanks for your reply...Mike |
Re: Oil filler tube
I think Classic Bowties still has em forsale.
https://67-72chevytrucks.com/vboard/...d.php?t=818966 |
