![]() Join Date: Jan 2001
Is your Bronco on fire? Ford has the fix...
Rather than actually fixing leaking injectors, Ford dealers will install a tube to allow the fuel to drain to the ground. They'll also install software to cripple your engine if the ECU senses low fuel pressure:
https://www.carscoops.com/2024/04/fo...blem-persists/ Is the ghost of the Pinto hanging around Ford headquarters?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
Who Changed This?
![]() Join Date: Jan 2013
Re: Is your Bronco on fire? Ford has the fix...
The pony is taking lessons from Edsel?
Throwing software at a hardware problem. Yes...it's been done before. In 2009 or so, bmw knew they had a hardware issue with their turbos on the new twin turbo 3 series (335). Indeed the fix was a software fix that reduced the engine output in an attempt to mask, delay, prevent turbo waste gate failure. This was met with a very huge outcry from consumers of these vehicles. Eventually they ponied up and fixed the engines with actual hardware but it took some pushing to make them do it right. Ferd is admitting there will be a fuel leak and they simply want software detection of leak to maybe shut off or put the engine in limp mode to provide safety...oh and a DRAIN PIPE? Jesus. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
![]() Join Date: Dec 2009
They pee fuel on the ground but we need EPA approved gas cans .
Dodge did something similar the 07 trucks and jeeps and other years when you shifted into park it sometimes was is reverse even though the indicator said park and you could turn off the truck and remove the key . The solution was to have the horn blow when you opened the drivers door . Instead of fixing the linkage and or trans . Real bandaid approach . I believe this is how the actor that played Checov in the new Star Trek movies was killed by his Jeep he got out walked behind the vehicle and it pinned him against the wall
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
#7 | |
![]() Join Date: Nov 2007
I am lucky that I live across a bridge from Canada. They have good ‘ol’ fashion gas cans at Canadian Tire. I’ve spilled more out of these EPA Cans than got in the tank.
1963 Chevrolet C-10 "Ginger" ![]() 1970 C-30 Dump Truck "Scarlet" 2019 Chevy Silverado 2500 Z71 LTZ 1947 Indian Chief Roadmaster with Sidecar. 2012 Indian Chief Serial #002 of 110 built in '12 2016 Indian Chief Roadmaster |
https://www.canadiantire.ca/en/pdp/s...rq=gas+can#srp
That is 23.23 United States Dollars I also think you can just buy the nozzles to, look at their website.
BlahBlahBlah
