02-26-2004, 02:31 AM | #1 |
invader motors?
Just like to say hello to everyone, I stumbled across this site and seems like there is a lot of good info here, so hopefully someone can help me out.
I have been searching for the last couple of days and all I can find is a site on the GMC Sprint in reagards to an INVADER 350. I just purchased a 350 invader on the weekend. I have never heard of one untill I saw it. From what I can gather they were made from 71-77 I believe, but thats all I can seem to find. So if anyone knows for sure what years they were made, what kind of horsepower they made, are they a good motor? Are they rare? Were they all 4 bolt mains(so I was told) or if you know of a link to a site it would be greatly appreciated. The fact that I cant seem to find anything on them really makes me think they are rare. Thanks |
02-26-2004, 09:45 AM | #2 |
"Invader" was the name that GMC used on all of their (Chevy) V-8 motors during that time period. It was just a sticker on the motor. I believe the Invader stickers were only used from '68 - '71. They are "rare" now because they were only used on GMC motors, and most of the stickers fell off or were covered with grime years ago.
Tim |
02-26-2004, 10:29 AM | #3 |
its all about the +6 inches
Welcome to the board from Central ohio.
Blazer is right...nothing more than a chevy 350. 4 bolt or 2 bolt...either way. Ge the numbers off the bellhousing, and off the machined pad up front in front of the passenger side head and we can tell you exactly what you have. If it is an early 70's engine, there is a good chance of it being a high nickle block. |
02-26-2004, 01:44 PM | #4 |
Thanks guys
I will try to get the numbers off the block this week and see what I have. If its a high nickel block, I assume that it would be a much stronger or thicker block, or what makes it better if its high nickel? Thanks |
02-26-2004, 03:23 PM | #5 |
driving is in my blood
high nickles just means its slightly stronger. People make big deals out of 4 bolt bottem ends and high nickles blocks but they really aren't anything to get excited about.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
02-26-2004, 05:16 PM | #6 |
high nickle blocks are quite a bit stronger against wear in the bore. I have seen 150,000 mile small blocks with so little ring wear that it wouldn't even catch your finger nail. The pistons came right out of that sucker, no ridge reamer needed.
02-26-2004, 06:23 PM | #7 |
I had a 72 that had the Invader motor in it, and was stock.......
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
02-27-2004, 11:43 AM | #8 |
My 72' 3/4 ton GMC has a invader 350.
72 GMC Camper Special 2500. currently has 350/350/14 bolt. 383 and 400 tranny is in the works. |
02-27-2004, 01:39 PM | #9 | |
Brian |
02-27-2004, 05:27 PM | #10 |
I was going to mention the cross hatch still being visable at 100K, but everyone says I am full of sh!t when i mention this.
02-27-2004, 05:49 PM | #11 | |
02-28-2004, 03:33 AM | #12 |
My old ladys Hyundai had it at 175K. Still running strong
02-29-2004, 02:17 AM | #13 |
My brother in law has a 95 Taho with 296,000 miles on it, does not use a drop of oil between oil changes. This vehical is amazing to me. The tranny has never ever been out of the car/truck ( SUV ) He changes the oil evry 3000 miles
72 LWB chevy truck. Pasadena, Texas |
02-29-2004, 04:29 AM | #14 |
Hi there
So I was able to get some numbers off the block. There is a 010 on the inside at the rear, this I see would indicate a block cast with 2% more nickel(very good) On the drivers side rear ledge I found k0226TBC which would indicate a canada made motor assembled feb. 26, which year Im having trouble with, as well as the TBC suffix. There is also a M6 at the rear of the block near the top. On the passenger side of the block I found all different numbers and letters. There was an A 9 or 3 by itself, then below it a D-N. There was also a series of circles with a sort of pie peice cut out, what it looked like was (0 will replace the circle) 0100A0029, hopefully this makes some sense. Its late and Im tired and tomorrow I will see if I can make heads or tails of the numbers a little better. The other number is 3970010 which tells me 69-80 but id like to narrow it down a little more. |
02-29-2004, 09:35 AM | #15 |
1970 TBC 350 convfwd cabs, a/t 255 4 C-10 to 3500
1970 TBC 350 m/t, 3 spd 255 4 K-10 & 20 1979 TBC 350 conv. cab, m/t,fed L LS9 165 4 C-10 to 2500 I am sure yours will be one of the 1970 applications, especially if it is orange. I think they changed to blue by '79.
Tim Last edited by Blazer1970; 02-29-2004 at 09:37 AM. |
02-29-2004, 02:18 PM | #16 |
Thank you, for the info. The motor is orange, so I think its safe to assume having the 010 on the back of the block, being orange, and having the invader stickers would mean its right around 1970. Now because of the 010 on the rear, that would eliminate the 1979 version would it not?
