05-21-2005, 06:30 PM | #1 |
Keep On Truckin'
CS130 Alternator wiring question
Has anyone installed a CS130 alternator (later model GM) and if so how did you wire it up? I have no idiot light for the alternator.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
05-21-2005, 09:02 PM | #2 |
The battery wire should be obvious. The S terminal isthe voltage sensing wire, hook the to the origional buss bar(red wires on DS fender well). The L terminal goes to a switched ignition source THRU A 35-100ohm 3+watt resistor. This circuit needs this resistor to keep from frying the electronics in the Alt.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
05-21-2005, 09:12 PM | #3 |
Its a Truck Thing......
So if you have the light do you still need a resistor?
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
05-21-2005, 09:37 PM | #4 |
^ no, use the light in place of the resistor.
05-21-2005, 11:15 PM | #5 | |
Keep On Truckin'
05-22-2005, 10:51 AM | #6 |
what about if you are using a voltmeter, would that act as the resistor?
05-22-2005, 11:20 AM | #7 |
^No.
05-22-2005, 06:34 PM | #8 |
Keep On Truckin'
I found a pigtail with the correct resistance in the wire that AC Delco makes for this; part # 8078 and cost $21.88 from Advance Auto parts.
05-22-2005, 10:11 PM | #9 |
Thats good to know, a lot of people have had trouble finding a resistor that will work.
05-23-2005, 11:04 AM | #10 |
Lovin' Life in Miss.!
Bought mine from partsamerica. http://www.partsamerica.com/ProductD...artnumber=8078
The truck... you hear that? No really, you did hear that?!!! |
05-23-2005, 03:18 PM | #11 |
Blue 67
When I switch to internal regulator alt few months ago, I bought 75 ohm 3 watt resistor from a local electronic shop; 50 cents each, Still working well. I just coverd the resistor in some kind of sheild to protect it from heat and possible trauma. I bought 3 of those. if you like I can look for them. I don't promiss to find them though since my place is a mess right now.
05-23-2005, 08:00 PM | #12 |
You could definately make a nicer harness than that jumper I listed. This was an easy way to go though. Just plug it in.
10-30-2005, 12:02 PM | #13 |
Msgt USAF Ret
Re: CS130 Alternator wiring question
Here is the cs130 conversion that I found on the board
http://www.chevelles.com/techref/tecref14.html
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
