12-15-2006, 11:23 PM | #1 |
Soft Tops For 69 to 72 Blazer
Help
I was wondering if anyone could give me info on a soft top for my Blazer. I am looking for someone who currently makes them. I am not interested in the Tiger top due to the snaps. I was looking at on from Specialty Tops but they are not making them any more because they arte being sold. I heard that some old employees from Kayline might be starting up to make them again. Thanks foryour help |
12-16-2006, 02:40 AM | #2 |
Global warming is a myth
Re: Soft Tops For 69 to 72 Blazer
I think you, me & everybody might just be screwed. I went to coloradok5 & saved all of the pictures in their can-back review. What I will do with the pictures is design a similar top, & take the plans to a boat awning shop, & have them stitch it up for me.
Will it take a while? Yes. Will it be expensive? Yes. Will it totally kick ass? We'll see. I have a TJ with a soft top as well, which doesn't leak AT ALL, so I'm going to try & duplicate a lot of the design elements from it into the blazer top. Maybe I'll sell the plans on EBAY or something & have myself a little side business. Later, Buddy
Henderson, NV 1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!! 1990 K5 with 37's 2003 Discovery SE7 - Wife's |
12-16-2006, 06:30 PM | #3 |
Just need a couple more parts.
try the search function on Soft tops.
there has been lots of posts. Here's one with 3 types on it. http://67-72chevytrucks.com/vboard/s...ight=soft+tops
--------------------------------------------------- 1947 Studebaker M5 project to match the camping trailer. 1950 Chev 4x4 Pickup 1958 Shasta Airflyte Travel trailer (fresh restoration) 1971 C/10 Pickup(Frame off Restoration) 1972 K5 Blazer CST (Daily Driver & My Company Truck) 1976 Honda CB750 Bobber 1988 Jaguar XJ12 |
12-16-2006, 09:28 PM | #4 |
The LuvShack Garage
I'd rather just have a 1/2 cab
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
12-16-2006, 10:57 PM | #5 |
I agree, now I just have find one. Cheap!!! J.
12-17-2006, 01:35 AM | #6 |
Back in the sticks
The tonneau for the 71 longbed has an aluminum frame that clamps to the bedsides and the snaps are mounted to it. I was going to try to find some of the aluminum channel they use and make a soft top frame out of it. Then just have some vinyl cut and sewn to fit with side and rear windows sewn in as well. Anyone tried a frankenstein job like that? Any ideas on a supplier for the aluminum channel? Its basically just a rectangular tube with plastic corners riveted on. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
12-18-2006, 01:31 AM | #7 |
SKINNY TIRES RULE!
Bestop makes a top for Blazers. My understanding is that Specalty Top Co is going to be backup and running in a few months.
I wouldn't hold my breath that CanBack will ever make a top for our trucks. They've been saying anytime now for over 4 years. Last I heard, they really had not intensions of building a top for first gen Blazers.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
12-18-2006, 07:26 AM | #8 |
12-21-2006, 05:27 PM | #9 | |
I figure if it'll cost 750 anyways, I might as well have the boat shop do it EXACTLY how I want it for 1000. Of course, I don't KNOW that I could get it done for that much, but I can dream can't I? Later, Buddy
12-21-2006, 09:04 PM | #10 |
Active Member
Are the soft tops available fairly water tight?
Mike T. Oregon 70 GMC Jimmy 4x4 70 Camaro LS1 plans in the works 71 RS/SS Camaro numbers matching 86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear) |
12-21-2006, 10:20 PM | #11 |
SKINNY TIRES RULE!
Fairly water tight. They leak around the door windows and where the door meets the windshield frame, but it's not too bad. If you live in a mild climate (like SoCal) they would work fine all year. They are a bit more drafty than the hard top for any place that sees any type of winter.
12-22-2006, 01:50 AM | #12 | |
Active Member
12-22-2006, 09:09 AM | #13 |
I think mine is a boat shop top, have never been able to ID one like it. It has some issues, but overall it works great. The biggest problem I have had is it holding water over the front seats and drowning you when you open the door after a rain. When leaving it out for a day or two I put a towel on top of the roll bars to give it a positive down slope.
12-22-2006, 09:43 AM | #14 | |
I probably try something with some pvc piping. I'd assume that you have some kind of frame around the windows right? Go to your favorite box, (lowe's, HD, etc.), or local hardware store & pick up some 1" PVC pipe. About 6-8 feet would probably be more than enough. Also, pick up (2) 1" tee fittings, for each "bow" you'll make. What you want to do is cut the t-fittings so that they look like this -C instead of this -O Hope this is making sense. Then you cut the pipe so that it is a little too long to fit in between you're door frames, so that it will bow when you put it in between them. Attach the "T's" & stick it in between the door frames. You may have to adjust the length a few time to get it just perfect, but I "think" that would solve the pooling problem. You could paint the PVC to match the interior or even wrap it in upholstery for a super trick, cheap fix. Merry Christmas!! Buddy
07-25-2010, 12:46 PM | #15 |
"Trucks with Class"
Old thread---but, I just saw this on Ebay: http://cgi.ebay.com/ebaymotors/ws/eB...d=190410277781
I think I like the looks of my old KLINE better. Remember when you could get these in all the colors? What happened? |
07-25-2010, 01:48 PM | #16 |
The LuvShack Garage
WoW, He has 10 of these available
07-25-2010, 04:16 PM | #17 |
Looks to me like he is just trying to overprice the new softoppers, and he doesn't even have all the colors. Here is a link to the same cover for a LOT less money, just by buying it from the manufacturer.
1972 Chevy K5 Blazer 1972 Chevy K20 1955 Chevy 3100 "If we knew what it was we were doing, it would not be called research, would it?" - Albert Einstein |
08-06-2010, 09:16 PM | #18 |
That's not the same as the SoftToppers.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
04-08-2011, 12:57 AM | #19 |
do any other companies make the soft tops for the 1st gen blazer or is softtopper the only one left?
06-27-2018, 10:36 AM | #20 |
Hey Guys, I have been searching on the internet for soft tops for my 72 blazer and found several companies that make them,
softopper.com, motorcityk5, and others, cost is $979 Has anyone purchased one of these. They say they are water tight, has fold down capablities, clear side and rear windows. Works in all four seasons. I was thinking about selling my hard top and buying one of these if I can leave it on all year. I only like driving it with the top down but sometimes rain gets in the way. Let me know what you think. JD
06-27-2018, 03:42 PM | #21 |
This K/5 I just got a few weeks ago has a new Soft Topper on it....
it fits very well and I did get caught in a rain storm with it... I didn't have but about 10-12 miles in the rain but there were no leaks that I could find
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
06-27-2018, 05:35 PM | #22 |
Man, I like that black blazer........ all of my vechicles are black except for my blue blazer...... may have to get the paint brush out.......
06-27-2018, 05:36 PM | #23 |
Does the top fold down behind the rear seat? That would be nice.
06-28-2018, 06:58 AM | #24 | |
https://www.softopper.com/jeep-suv-t...-blazer-gen-1a
06-28-2018, 07:13 AM | #25 | |
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
