Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 10-21-2017, 03:36 PM   #1
KIC
1960 GMC Burb
KIC's Avatar
60 Burb Radiator
So I decided to get the radiator repaired as it has a leak. To get it completely done the shop wants $500. Some of the replacement ones seem to run between $380 -450. I am thinking that it would probably be better to get the original fixed and keep it original ...any input ?
1960 GMC Suburban
1/2 ton V-6
2nd generation original owner
60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban
60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs
2003 Tahoe LT
KIC is offline   Reply With Quote
Old 10-21-2017, 11:32 PM   #2
Captainfab
60-66 Nut
Re: 60 Burb Radiator
If you can get a good quality radiator for the $380-450, I would go that route rather than messing with the old radiator.
Old 10-26-2017, 12:09 AM   #3
61ChevyPanel
Active Member
61ChevyPanel's Avatar
I paid $380 to get my old one redone, about the same price as a new aluminum one. I've heard it's not easy to repair aluminum ones and I don't think they last as long.
61ChevyPanel is offline   Reply With Quote
Old 01-30-2018, 10:39 PM   #4
KIC
1960 GMC Burb
KIC's Avatar
Re: 60 Burb Radiator & Hoses
I bought an aftermarket radiator. Not thrilled that it is a chrome one, will probably work on a color change at some point. I thought I would post some info on this thread for future searchers looking for hose information.
The aftermarket radiator had a smaller diameter lower hose nipple on it which required a hose with different sizes on each end.
Spent a lot of time searching for the correct ones on both the upper and lower hoses since I did not want a "ribbed" generic type hose. I found one that would work at Merles Auto/NAPA Auto (same company now)
The bottom was next to impossible to find, but after having a helpful counter guy show me many hoses that I picked from their catalog, I found a bigger longer lower hose that had the two different sizes that I needed due to the new radiator.
I had to cut the bottom hose to fit as it was way too long and had two many curves, but it had the perfect length and curves built into the overall length of the hose so I cut the hose to fit my need and the rest of the curves and stuff was cut off and tossed.
The top Hose: Dayco 70344
The Bottom Hose: Dayco 72033
1960 GMC Suburban
1/2 ton V-6
2003 Tahoe LT
