![]() Join Date: Jan 2017
Inner panel protection
I am aware of the different methods of out side finishes. What about the important inside finishes for long term protection.
I'm asking about the inner sides of the fenders, cab and bedsides. What do you do to preserve and make a long lasting coating to preserve those parts? I will be doing a full restore and want to drive the thing so I'm not worried about cost of doing it right. I'm more concerned about doing it right and not destroying all the money spent on the restore to watch it rot from the inside out in time. What are the best methods to restore a driver all the way? Thank you |
Re: Inner panel protection
3M™ Cavity Wax Plus
This non-hardening, self-healing coating will not chip, peel or crack, and is designed to cover and protect internal joints, hem flanges and compromised e-coats where corrosion can form. A convenient aerosol spray can eliminates the need for bulk spray equipment. part number 08852 great stuff |
X2 - 3M sells a wand kit for it also. P/N 8851, has 3 tips, 8", 24" & 34".
Thank you, I will check it out
Has anybody ever used Fluid Film. It was originally designed to use in the marine world to protect the metal from slat water to reduce or minimize rust. Industries up north use it to coat their fleet vehicles for winter and such. I use it on all of my tools and any metal that that will be exposed to harsh conditions. It can be applied with brush or spray.
Start with an epoxy primer, then urethane paint. This is a time tested proven anti corrosion process.
You can use fish oil or any other tonic that suites your eye, because the epoxy and urethane is 99% of your corrosion protection requirements.
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
I agree with the wax coatings and to epoxy prime it first, pour it in there, if you have to. But this gun is a goodie! http://67-72chevytrucks.com/vboard/s...d.php?t=765811
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
![]() Join Date: Aug 2015
Agree on the 3M cavity wax, just used it myself. Something to remember though. If you need to do any more welding. It will flame up. Lol
A Little Better Every Day Cancer Survivor, most dont know what they have until its gone, appreciate everything |
Ha ha, sounds like you learned that the hard way!
