73-87 Frame Help
I have a 84 c10 2wd swb truck that just encountered some frame damage. I guy is giving me a free 78 frame if I want it. Question is can I used this 78 frame with the 84 body. Read that the front end needs to be trimmed but is there any other obstacles one my encounter. I'm hoping it's a direct swap from one frame to the other. Any help is always appreciated.
Re: 73-87 Frame Help
Why not take your frame to a shop to get your realigned?
73-80 frame is different at the front for bumper. Body will fit fine. If you want to use the 81-87 style bumper that will be your biggest work around.
69 Camaro Z/28 72 c-10 454 th 350 86 k 30 454 4 speed 96 k 1500 350 vortec |
#4 | |
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
Almost Satisfied
![]() Join Date: Mar 2002
You don't need to cut the front of the frame. Cut the bumper brackets instead. The cab mounts are different as well. You can swap the perches or swap the rubbers. E-brake was different on my 85 versus the 78 frame I am using, but I have seen some early 80's that are using the same E-brake setup as the older models. I just put an 85 body on a 78 frame. Let me know if you have questions
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
Thanks to all for all information provided.
One thing not mentioned is the VIN will be different on the frame vs the body if you go that route. Document the frames VIN just in case it ever comes up (theft).
![]() Join Date: Apr 2013
Your body mounts need to match the frame.. not the Cab... front frame horns will need to be reworked to fit the newer style bumper... also the E-brake mount is different
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
Almost Satisfied
You do not have to cut the front frame horns! Cut the brackets.
good info...
