Alright Alright Alright
What grit for sanding off clear coat?
I plan on removing the already peeling clear coat off of my truck and I was wondering what would be a good grit of sand paper to do the job.
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
Re: What grit for sanding off clear coat?
no such thing ... if it will remove the clear then it will remove the base coat as well. your best bet is to sand it down and do a complete respray.
Your right. The funny thing about this site (which I have been a member of for 7 years) is any time I try to take a short cut on something, regardless of forum, someone is always there to correct me. I like that.
Thare are always different levels of "right"
Im the king of short cuts but if this is a important ride and you don't know how it was done before. Take it to bare metal and go from there. Which is real easy if you use "aircraft" stripper from autozone. litteraly in 3sec the paint will just fall off, no scrapin, scrubin, sandin, bare metal in the blink of an eye. And as such the stuff will burn the heck out of you if it gets on your skin. But once hit with water it stops the effects.
Chevy GMC Trucks Find Of The Day https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com |
That stuff is great. I have used it before. I have also used it to remove carbon and oil on engine parts.
you do want to take the whole pannel to metal or u are just askn for trouble however u want to do it is up to u something went wrong with the process/material that was used
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
I wolud try to sand a panel with 220 grit and spray 2-3 coats of high build primer. Not all trucks need to be stripped to bare metal, some do some don't. If the truck is crazing or craking or lifting by all means strip and then epoxy prime. Jim
You can't tell w/o looking at it or a decent pic. but we sand with 80 grit . epoxy primer to suit and then B/C . as stated no reason to take to bare metal. Whats the sense in that?
i quess u know best
Most feel that they have to strip. It is a lot of extra work and is uneeded in a lot of cases. Like I said in the above post if you don't have a cracking or frying of the paint stripping is a lot of work sometimes for nothing. Jim
