Old 05-10-2011, 12:55 AM   #1
87chebby
1987 (Vss)Vehicle Speed Sensor location
I am getting code 24-vehicle speed (vss) sensor circuit fault.
I am not sure where the sensor is located. If anybody could advise me of where it is located I would appricate it.Also if anybody has ever had the same code give me some feed back on what it exactley was. Appriciate it
87chebby is offline   Reply With Quote
Old 05-10-2011, 05:20 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 1987 (Vss)Vehicle Speed Sensor location
LOL, the sensor is located on the trasmission tail housing. Is your speedo working correctly?
24 VSS Set when in motion only - disregard if set in park
http://www.cfm-tech.com/gm_tbi_trouble_codes.htm
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 05-24-2011, 05:39 PM   #3
djunkie
djunkie's Avatar
I just checked on my '87 and I am getting the same code. Speedo works when the truck is cold but after a few miles it stops working. No speed sensor on the transmission tailshaft on my 700r4. Just and adapter with the cable coming out of it that goes to the speedo. Is there a speed sensor behind the speedo?
djunkie is offline   Reply With Quote
Old 05-25-2011, 09:19 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Little green box behind the instrument cluster.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 05-25-2011, 10:02 PM   #5
djunkie
djunkie's Avatar
Ok cool. Is this something I can get from a local parts store or am I gonna have to order online somewhere?
Old 05-26-2011, 09:49 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
1989 burb
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-02-2012, 08:13 PM   #7
chris989
What was the outcome of your speed sensor issue?
I have a 89 and i feel mine is affecting my timing but i never get any codes.
If i put my truck in neutral while drifting even at 5mph my idle increases to 1500 rpm.
chris989 is offline   Reply With Quote
Old 01-03-2012, 06:42 PM   #8
djunkie
djunkie's Avatar
Mine ended up being the speedo cable adapter at the trans. I removed it then went to a speedo shop to have the gear changed in the trans to calibrate it. Been fine ever since.
