Old 08-04-2011, 03:11 PM   #51
Rdrdave
Broke and still trying
Rdrdave's Avatar
Re: Show me your rims - 6 lug options
Those 15x14s are sweet! I have 15x10 Weld Typhoons on 35 Xterrain Pro-Comps on my k5 and 15x7 front/ 15x10 rear Corvette Rallys on the 68.
Rdrdave is offline   Reply With Quote
Old 08-04-2011, 07:25 PM   #52
viking427
[QUOTE=bigbadchev72;4823194]15x10 Corvette Ralleys
Where are y'all getting these Corvette style center caps with the middles hollowed out for 4wd front hubs ?
viking427 is offline   Reply With Quote
Old 08-04-2011, 08:45 PM   #53
bigbadchev72
People know me
bigbadchev72's Avatar
[quote=viking427;4828223]
You have to hollow them out yourself. Lots of patience and a dremel.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 08-06-2011, 02:37 PM   #54
joemacho
joemacho's Avatar
heres mines with centerline and mickey thompson baja claws ttcs 15x12 rims and the tires are 33x12.50x15s whats wierd about these rims ive seen rims like alcoas, michey thompson, eagle, american racing, center lines all look the same.
1972 gmc jimmy project comin soon ( jus a sin )
1959 chevy apache shortbed fleetside (brsgrm)
1966 Chevy c30 duallie 2wd (big chief)
joemacho is offline   Reply With Quote
Old 09-21-2011, 08:12 AM   #55
Blazer 1972
I have a 1972 Blazer that I would like to mount stock type steel wheels on. I believe the stock rims are 15 x 6, 6 lug. I would like to go to 15 x 8, 6 lug, to fill the wheel wells out a bit better. Does anyone know where I can purchase these? Thanks!!
Blazer 1972 is offline   Reply With Quote
Old 09-21-2011, 10:20 AM   #56
viking427
Topic has surfaced before, check here; http://67-72chevytrucks.com/vboard/s...highlight=15x8
Old 09-21-2011, 11:58 AM   #57
Firebirdjones
Dig around enough and you'll turn up a set. I found some here local for mine. I decided to go the steel wheel route too, since aluminum wheel choices are drying up, most don't have the correct backspacing needed unless you want to spend $200 a wheel.
Firebirdjones is offline   Reply With Quote
Old 09-21-2011, 02:59 PM   #58
BBrendal
Recalculating.....
BBrendal's Avatar
Try this...
http://67-72chevytrucks.com/vboard/s...d.php?t=476651
Brian - (BBrendal)
1969 Chevy Camaro Z28
1972 Chevy Blazer CST
2004 GMC Yukon (The truck that pulls the car trailer)
1972 Chevy Blazer CST #2 (Finished and sold!)
Blazer build link...
http://s1213.photobucket.com/albums/...rendal/Blazer/
BBrendal is offline   Reply With Quote
Old 11-01-2011, 09:27 PM   #59
joemacho
joemacho's Avatar
heres another shot of the rims i reacently aquired there 15x14s craggers i think i had some center line caps layin around i have them on for now but i was thinking of drilling and tapping and installing the rally caps what you all think...
Old 11-02-2011, 04:32 AM   #60
mustardjimmy71
toys'r'us
mustardjimmy71's Avatar
do it but paint the center sectioin on the rim black and leave the rim polished. The flat color of the cap looks wrong on the shiny wheel. Painting the center section of the rim will break it up nicely
71 jimmy bone stock 350 sm465 33x12.5 rallies
79 caprice landau full load crate350 th350 lowered 20"wires
00 f150 reg cab sb 4x4 5.4L
mustardjimmy71 is offline   Reply With Quote
Old 11-05-2011, 12:38 AM   #61
CTENTA1
Registered 1971 K5
I like them better with out the caps.
CTENTA1 is offline   Reply With Quote
Old 11-05-2011, 02:11 PM   #62
Firebirdjones
Polished wheels look better with the chrome caps they were intended for, and they aren't that expensive. Install what's supposed to be on there and leave it be. Drilling any holes to mount different caps, or even painting the wheels, is going to make for a very tough sale if you ever want to get rid of them.
As far as painting the wheels black, you may as well buy a set of steel wagon wheels for that and keep those for your offroad setup. Leave the aluminum polished.
