Old 11-19-2012, 08:30 PM   #1
SnS C10
SnS C10's Avatar
shortened steering column and floor shift conversion..complete
im off all week so i figured i would get a few things done today. this past weekend i converted the old three on the tree to 3 on the floor. bought the spectre floor shift conversion kit which was missing two shifter arm brackets. cnc cut two new pieces at my work and they fit perfectly. loc tited all bolts and put a cotter pin through the bolt that holds the shifter to the trans bracket. i also cnc machined the shifter knob and had it painted. today, i shortened the steering column by 3 inches. looks much better, imho. hope you guys like the updates
SnS C10 is offline   Reply With Quote
Old 11-19-2012, 08:47 PM   #2
c10monkey
c10monkey's Avatar
Re: shortened steering column and floor shift conversion..complete
Looks good!
Can you show a pic of what your column looks like at the firewall inside and out?
1971 Chevrolet C10 Inflation Fighter
1994 C3500 Crew Cab Dually 454
c10monkey is offline   Reply With Quote
Old 11-19-2012, 09:20 PM   #3
midniteblues
midniteblues's Avatar
I bet it's alot more fun to shift now. cool shift knob also.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 11-19-2012, 09:28 PM   #4
Street Smart
Street Smart's Avatar
I like it!
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 11-19-2012, 10:22 PM   #5
AirSpeed
AirSpeed's Avatar
Looks great! I dig the shift knob!
AirSpeed is offline   Reply With Quote
Old 11-19-2012, 10:48 PM   #6
SnS C10
SnS C10's Avatar
c10monkey, i will take some pictures tomorrow when its light out. I took the nuetral safety switch off. i believe it would be about half way in and half way out of the firewall. to bypass, i bridged the wires together. thanks for the nice replies guys, im very happy with it
Old 11-20-2012, 12:40 AM   #7
no_rice
i just pulled the seat and flooring out of the 70 gmc i picked up not long ago. it was originally a 3 on the tree, but when i got it, it was auto column and auto trans.
when i pulled the flooring out, someone had put a hole right were your shifter is, and thats the first thing i thought... someone made it floor shift. i actually wouldnt mind getting a 3 on the tree trans back and doing what youve done.
no_rice is offline   Reply With Quote
Old 11-20-2012, 09:19 PM   #8
Secret Squirrel
Secret Squirrel's Avatar
Previous owner did the floor shift conversion on my truck, I need to adjust the linkage (but that's another story). I went out and bough the boot for the floor, looks like we shopped at the same place. From the looks of my stock steering column it looks to be more than three inches. I like it, being 6'1" the stock wheel is in my chest. Pretty neat.
________________________
72 Olds Cutlass w/442 option
69 C-10 Short Bed Fleet
1960 Biscayne Wagon/El Camino
1995 YJ 4.0 SOA SYE on 35s
01 Excursion Limited 7.3 PSD
06 Suzuki DRZ 400S
Secret Squirrel is offline   Reply With Quote
Old 11-20-2012, 11:31 PM   #9
SnS C10
SnS C10's Avatar
it may be closer to 3.5 to 4 inches, i forgot to measure. pretty easy to do as well. Im 6'3 220 but before i shortened, it was not too close. I just prefer the custom look of having the wheel closer to the dash. I bought the boot along with the shifter at pep boys, the shifter was around 35 bucks on sale, and the boot was 14.99.
Old 11-20-2012, 11:32 PM   #10
SnS C10
SnS C10's Avatar
secret squirrel, since i have no engine in my truck yet, im not sure what the shift pattern is? i assume yours is a three speed correct? so.....if sitting in drivers seat, where is first, second, third and reverse?
Old 11-21-2012, 11:06 AM   #11
Secret Squirrel
three speed, yes
Shift pattern is H pattern (reverse top left, then down to first. Top right is second bottom right is third,)
06 Suzuki DRZ 400S
Old 12-22-2012, 10:04 AM   #12
68_chop_top
68_chop_top's Avatar
I shortened my steering shaft AND dropped it down a little. I chopped my cab so I had to put the bench seat on the floor. I removed the gas tank so I could put the seat as far back as possible. I am 6'1" and 210 and I looked like an ol' grandma with the steering wheel too close and too high. Lowered cab means lowered seat which means lowered and shortened steering column. I love the factory steering wheel. I like the strap on tach cuz thats the way I did it in high school. My tranny then was a T-5 5 speed. Now I roll with a Tremec TKO600 5 speed.
Mine is chopped, has a clutch, and a big block.
68_chop_top is offline   Reply With Quote
Old 12-22-2012, 12:30 PM   #13
67ctener
67ctener's Avatar
Is there a link or info I can find about shortening my column? I have a factory tilt and auto column that I'd like to keep but shorter would make a world of difference
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 12-22-2012, 12:50 PM   #14
leddzepp
Moderator
leddzepp's Avatar
You need to collapse the intermediate shaft so it looks like the pic in post 15
http://67-72chevytrucks.com/vboard/s...d.php?t=133937
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 12-22-2012, 01:52 PM   #15
67ctener
67ctener's Avatar
Thanks I will be doing this for sure
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
