Closed Thread
Old 06-30-2013, 01:39 PM   #7301
Re: What did you do to your truck today!
Originally Posted by gottattooz View Post
I installed a "toothed" grille from a 59 Chrysler Imperial, cut up the stainless to accommodate the new opening, and relocated the stock turn signals.
-Josh
That looks good Josh!
Palf70Step is offline
Old 06-30-2013, 02:00 PM   #7302
jayman68
Fun Stuff
jayman68's Avatar
Originally Posted by ryanroo View Post
that thing is huge. ive never seen a slug that big.
I guess you haven't been to Western Washington. They get pretty big around here.
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline
Old 06-30-2013, 02:31 PM   #7303
jabborabbo
jabborabbo's Avatar
Replaced the cab mounts on my '67 GMC all by my lonesome. The front bolts weren't tack welded fortunately - using a wrench inside a pipe for the head and a torque wrench on the nut I was able to torque 'em down to spec!
jabborabbo is offline
Old 06-30-2013, 03:28 PM   #7304
apacheben
apacheben's Avatar
Went outside , started it up. talked to it for 5 mins.
I love my 58 chevy apache. is that wrong ?
apacheben is offline
Old 06-30-2013, 04:24 PM   #7305
jabborabbo
jabborabbo's Avatar
If that's wrong then I don't wanna be right!
Old 06-30-2013, 08:44 PM   #7306
OregonNed
OregonNed's Avatar
I finished my under hood wiring cleanup project. It included running the wires properly through new firewall and radiator cable channels. Also any and all erroneous wire performing no function that was installed by the PO was removed. All wires exposed were wrapped in black wire tape. I also reattached the cowl after installing a more period correct antenna, trash guards and a new hood to cowl seal. On the engine I replaced the painted water neck with a nice polished aluminum version to tie into my aluminum covers and cleaner. During the wiring project I broke a front side marker lens so I replaced them all new on all four corners.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 06-30-2013, 08:58 PM   #7307
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Took the blazer camping at the coast this weekend...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 06-30-2013, 09:24 PM   #7308
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Good weekend. Got the shifter lined up so P means park and D means go. Lubed the column so the shifter works again. Got the glovebox door back on. Installed return/return fuel line so it doesn't slosh out every time i go around a corner. Cleaned it up a bit. Ordered a overdrive shift indicator along with the anti-rattle bushing. Was able to drive it for a bit.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline
Old 06-30-2013, 09:48 PM   #7309
gvw5400
gvw5400's Avatar
Went for a 1.5 hour drive with my wife in the mountains. First long drive after having the sm465 rebuilt, shifts great. It sure is nice not having to short shift into 4th gear at 20mph because 3rd gear sounded like a air raid siren!
gvw5400 is offline
Old 06-30-2013, 10:28 PM   #7310
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
i'm definitely sick. I have been a stupid wreck since I dropped RAT off with Painter Lee on Wed.
Really lame of me. But, I guess after rolling around under, over, and in her for four years, I gotta have some pain in letting her out of my sight.
Let alone, the drag of being unable to drive her now that (most of) the bugs have been squashed.
Lee's a great guy and excellent body/paint artist. I promised him I wouldn't bother him so he didn't have to deal with me hanging out interrupting
him all the time. And, I won't...I just have to keep telling myself, "Remember your promise, promise, promise....".
Today, I was shaking enough () that I figured I better get a real life. So, I practiced some scales.
I got sick of that and figured that since I'd been asked a bunch of times about RAT's stance (I appreciate the questions), I'd make a little slide show
with captions to point out what RAT is running next to the ground.
Here it is:
http://tinyurl.com/jvpea2b
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 06-30-2013, 10:39 PM   #7311
rincones
rincones's Avatar
Extended the wheel tub width and height.
http://67-72chevytrucks.com/vboard/s...d.php?t=532127
Rincon
rincones is offline
Old 06-30-2013, 10:41 PM   #7312
FRENCHBLUE72
PROJECT 7DEUCE
MEMBER #6377
Project "7DEUCE"
Old 07-01-2013, 12:46 AM   #7313
farmall
farmall's Avatar
Removed grill and surround. Removed, cleaned and painted surround supports.
Cleaned and painted rad support. Bought new lights and grommets for the new to me 10' flat bed. Started to install new hdw on new grill and surround.
4 day weekend coming up and hope to get new grills and bumper installed, then blast and paint the flatbed.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline
Old 07-01-2013, 09:23 AM   #7314
Lou Boffa
Lou Boffa's Avatar
Rear Bilstiens installed. Much better. Removed, cleaned and painted tail light housings.
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline
Old 07-01-2013, 09:28 AM   #7315
bgwss
bgwss's Avatar
What was the part number on the Bilsteins?
1967 custom 351E V6 3/4 long bed
bgwss is offline
Old 07-01-2013, 09:32 AM   #7316
Lou Boffa
Lou Boffa's Avatar
24-002486 is what's on the boxes.
Old 07-01-2013, 09:56 AM   #7317
67cheby
67cheby
67cheby's Avatar
did a little sheet metal work on the notch cover
67cheby is offline
Old 07-01-2013, 01:31 PM   #7318
vegadesign
vegadesign's Avatar
ran 3/8 copper lines for the rear bags, and made a new bridge with chromally.
front bags will be next weekend
"its not a hobby, It's a Lifestyle"
bagged and soon to be bodied 70 longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=564028
vegadesign is offline
Old 07-01-2013, 06:13 PM   #7319
Lou Boffa
Lou Boffa's Avatar
Just ordered the fronts from O'Reilly part # Bil 24-192941.
Old 07-01-2013, 06:21 PM   #7320
Shortie
Junior Member
Shortie's Avatar
pulled the tranny back out
Shortie is offline
Old 07-01-2013, 06:25 PM   #7321
vegadesign
vegadesign's Avatar
story of my life
Old 07-01-2013, 06:31 PM   #7322
GMC69
GMC69's Avatar
Converted the old points system to HEI on my dads 72 cheyenne and got my 70 back when I dropped his off.
Mike
Email: Click here to email me
2019 Silvedrado 4x4
1970 Chevy 3/4 ton, 396BB, on air bags
GMC69 is offline
Old 07-02-2013, 09:00 AM   #7323
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today!
Be aware that Bilstein has HD #'s and those are the ones you'll be wanting .
The Sock Warehouse is so far , the best place to get them price wise , always in stock too .
Plus , they're connected to an outfit that sells brake shoes super cheaply , no core charge , riveted typ if you want .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 07-02-2013, 03:30 PM   #7324
MSHax
MSHax's Avatar
WOW! Looks like rincones and 67cheby did some positive work on their beds/wells. I went the other way, didn't want to replace the bed floor and wheel wells so I figured it would be much more fun to do a spray on bedliner instead. Don't want to fix the dents? Cover them up!
I stopped adding up how much I spend on my builds, it only makes me doubt my sanity knowing I've spent more than 9 times it's original value new.
MSHax is offline
Old 07-02-2013, 03:31 PM   #7325
Lou Boffa
Lou Boffa's Avatar
Good tip. Checked w Shockwarehouse.com and those are HD #'s...but they are $6/shock cheaper. O'Rielly will price match. Thats more beer for me. See why this is a great forum. Thanks Nate.
Closed Thread
