03-15-2017, 10:45 PM | #1 |
Highlander with a lazy rh eye....
http://https://goo.gl/photos/pxHYaHVYGtMuwxEh8
http://https://goo.gl/photos/e3Jh8cocjzso9egz6 I'm not figuring out what is causing the misaligned headlight...I've tried a correct year headlight bucket, thinking that was the problem because it didn't match the drivers side & that wasn't it...I did notice the passenger fender is a aftermarket piece. Could this be the problem? Or, is something bent behind the grille that I can't readily see?
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold Last edited by rustytruck50; 03-15-2017 at 10:54 PM. |
03-16-2017, 01:01 AM | #2 |
Re: Highlander with a lazy rh eye....
looks like youve hot broken or missing adjuster.
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
03-16-2017, 08:31 AM | #3 |
I'll check that again, but I think everything was there...thank you for the advice!
-Doug '05 RCSB Sierra 2WD '71 Sierra 2WD Longbed '98 Silverado K1500 Xcab...sold '72 Highlander"Raymond"...sold |
