Old 10-19-2017, 07:07 PM   #1
mikebGMC70
Disc brake tie rod question
I have a 1970 gmc c20. I'm upgrading to front disc brakes, I have drop spindles for 71 n up. I know I need to get year correct ball joints, can I just update the whole steering linkage to 71 n up? Thanks
mikebGMC70 is offline   Reply With Quote
Old 10-20-2017, 10:41 AM   #2
Pro Performance
Pro Performance's Avatar
Re: Disc brake tie rod question
We have a adjust sleeve that will convert from a early inner to later outer. It is 5/8" on the inside and 11/16" on the outside. No need to change all the linkage, and can just update your tie rod ends.
http://www.azproperformance.com/Alum...71-87-C10.html
Pro Performance is offline   Reply With Quote
Old 10-20-2017, 11:25 AM   #3
mikebGMC70
That is my original plan was to use to the conversion sleeve but was curious if I could just use later year components since I am putting new linkage in anyway.
Old 10-20-2017, 11:26 AM   #4
Pro Performance
Using all later components will work as well.
