10-24-2017, 08:26 PM | #5926 |
Re: P.S. Hose Service
Thanks Nate for the advise! Just received a new pressure line from Summit and it has male fittings on both ends--the one I removed has a female fitting on the pump end. I searched around and found GATES #14158-05283370 has a female end for the male pressure port on the pump. Might check NAPA. SUMMIT only listed one for 69-70 K/10--I wonder if I might have a 68 pump or one from a car or if EDELMANN hoses made in MEXICO installed the wrong fitting. Thanks for the filter idea.
10-24-2017, 08:48 PM | #5927 |
Re: What did you do to your truck today? Chapter II
Before anything else look at the pictures of P.S. hoses on Rockauto.com to see of mayhap they sent you the wrong one ~ it happens, I have the decades of stories to back that up .
I have worked on an old truck once or twice . I forget where I bought the new P.S. hose for my '69 C.10, maybe NAPA ? they too will have a picture but usually only _one_ to choose from . Filters are always a good idea on older rigs ~ I retain them as I flush any system until the ATF remains translucent and sweet smelling, then I discard them .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
10-24-2017, 08:56 PM | #5928 |
I just found the NAPA filter, think I will get one-good idea! Happy Trails
10-24-2017, 10:40 PM | #5929 |
I adjusted my quadrajet thanks to Geezer for the help. Also installed fuel filter and some vacuum hose. Tomorrow I will install an HEI distributor and wires hopefully!!!!!!z
10-24-2017, 11:19 PM | #5930 |
Rehabbed my Unity spotlight
1969 GMC K25 2007 Chevy 2500HD Classic Duramax 1999 Tahoe 2DR 4WD Base Model 5.7l |
10-25-2017, 07:27 PM | #5931 |
Unity Spotlights
? Is there any place that still sells the correct white handles ? .
TIA,
10-25-2017, 08:50 PM | #5932 |
Finished the trim and installed it on the truck.
1972 GMC 1500 Super Custom, 383 Stoker, TH350 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=592157 Engine Thread http://67-72chevytrucks.com/vboard/s...d.php?t=592233 |
10-25-2017, 08:59 PM | #5933 | |
My handle grip is black, FWIW. Posted via Mobile Device Last edited by Hotcorner; 10-25-2017 at 09:19 PM. |
10-25-2017, 09:30 PM | #5934 |
KY_GMC the trim really looks good with the rim colour, nice job.
Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
10-25-2017, 09:40 PM | #5935 |
Still on lwb to swb project. Only have a few hours each day. 72 frames are a little different so there where some questions that needed answered, Jamie at Brothers took care of that and now should be able to go back together as soon as I get the rear frame cleaned and painted
10-26-2017, 04:45 PM | #5936 |
Nothing,
Camshaft received broken from Summit (ship to France) no bubble wrap at all, I am curious how it can be possible to gamble at that point. Anyway, after a quick chat, they’ve sent me a new one |
10-27-2017, 10:47 AM | #5937 |
Cleaned up my fan today. Still have to paint though.
10-28-2017, 03:30 AM | #5938 |
I bought more hoses and figured out how I am going (I think) to fix my radiator hose problem long term and get the engine running short term.
10-28-2017, 01:40 PM | #5939 | |
It's good to know they're available again . FWIW, yours would have been white when new . I saved quite a few off 1970's vintage Police / Govt. vehicles but all were used over the years .
10-28-2017, 10:57 PM | #5940 |
VWNate1, I took Your advise and installed a P/S filter with the new pressure line. Had to remove inner fender to install the new line because of higher profile. Was easy once the inner fender was out of the way. Test run tomorrow! Thanks again for Your information!
10-29-2017, 01:41 AM | #5941 |
Active Member
I scraped the quarter inch thick layer of oily dirt off the front of the frame, sprayed it in simple green, then pressure washed it. Man what a disaster. It's a lot cleaner tho...
David Larsen 1970 Chevrolet C-10 |
10-29-2017, 01:49 AM | #5942 |
At the body shop.
Washed Old blue and went to the trunk or treat.
" That didnt make it any newer " " Dont antique the equipment " |
10-29-2017, 02:40 AM | #5943 |
Hooked up last of the radiator hoses. Bought distilled water and concentrated antifreeze. Ordered a new gasket set. Installed gasket under water neck. Bought and installed new air filter.
Can you guess what I am about to do? |
10-29-2017, 11:53 PM | #5944 |
Built and installed an enclosed air cleaner box / computer box.
10-30-2017, 09:33 AM | #5945 |
10-30-2017, 01:04 PM | #5946 |
I'd never really bothered to look, but I needed fuel this last weekend, and instead of using the regular non-leaded and stabil, I found a station a couple of miles away that vends super non-ethanol, 92 octane - so I know where I will be going from now on. Decided to throw in a can of Seafoam for stabilizer over the fall and winter, but I do start and warm it up every week or so - and on dry days take it for a spin..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
10-30-2017, 01:44 PM | #5947 |
....ahh, did my oil change....and added a little MMO in there.
Just nice to do in a way....and always good piece of mind knowing its clean again. Now......time to start getting ready to find a good 'paint' partner and bring some of the other parts of the truck up to scratch. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
10-30-2017, 02:07 PM | #5948 |
laying low
I want some of what he’s using!
10-30-2017, 07:43 PM | #5949 |
What did I miss here? Did you start on another one??
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
10-30-2017, 07:50 PM | #5950 |
I stared at it in shame!
