03-02-2018, 02:59 AM | #1 |
Cross Member
Is The 84 V8 Cross Member That Same As A 87 V8 Transmission Cross Member
Thank You For Any Info They Look The Same ? Harley03joe MINE
1931 Ford Like New And For Sale 2004 Harley Davidson Heritage Classic 1987 Chevy R 10 Silverado 2007 Azera 2011 Cadillac CTS Premium Last edited by Harley03joe; 03-03-2018 at 03:38 AM. |
03-02-2018, 07:02 AM | #2 |
Re: Cross Member
lots of crossmembers what 1 ?
but in general if same body style and 2wd or 4wd to same should be .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
03-02-2018, 01:06 PM | #3 |
Re: Cross Member
If you're talking about the front crossmember/spring perch for the 2wd then all the 2wds in any engine size are the same in the there respective series. 10s match 10s, 20s match 20s, ect... I've swapped a few and never had and issues no matter the year or engine though the GMC ones are supposed to be thicker from what I've been told.
03-02-2018, 01:09 PM | #4 |
Re: Cross Member
*thicker as in stronger not wider* not to confuse anyone they fit the same from frame to frame.
03-03-2018, 03:19 AM | #5 |
Re: Cross Member
Sorry Its The Transmission Cross Member
1931 Ford Like New And For Sale 2004 Harley Davidson Heritage Classic 1987 Chevy R 10 Silverado 2007 Azera 2011 Cadillac CTS Premium |
03-03-2018, 08:54 AM | #6 |
Re: Cross Member
major changes are 2wd or 4wd . and 1/2-3/4 ton and 1ton on its own .
so you should be fine.
03-03-2018, 11:32 AM | #7 |
Re: Cross Member
I installed that same cross member in my 68 when I put the overdrive in
03-03-2018, 06:32 PM | #8 | |
Re: Cross Member
Harley03joe
03-03-2018, 11:46 PM | #9 | |
Re: Cross Member
What Service Are Folks Using To Up Load Photos ? I Paid For Photo Bucket And Still Get 3RD Party Hosting Blocked ? Thank You Harley03joe MINE OTHER
1931 Ford Like New And For Sale 2004 Harley Davidson Heritage Classic 1987 Chevy R 10 Silverado 2007 Azera 2011 Cadillac CTS Premium Last edited by Harley03joe; 03-03-2018 at 11:54 PM. |
03-04-2018, 06:52 AM | #10 |
Re: Cross Member
Can't tell from your picture but I removed the other one from my V8 1985 2WD 1/2 ton. it originally had a 305 with a 700R4 trans. Mines a long bed if that makes a difference.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
03-05-2018, 02:29 PM | #11 | |
Re: Cross Member
Thanks Harley03joe
03-08-2018, 05:03 AM | #12 |
Re: Cross Member
I'm Going To Cut The Lip Off The Trans Cross Member So I Can My Deep Aluminum.
Trans Pan Up On It , You See The Front Lip Of The Trans Cross Member Is In The Way Tel You What You Guys Are Thinking OK ? Thank You For Your Input Harley03joe Pictures Attached
1931 Ford Like New And For Sale 2004 Harley Davidson Heritage Classic 1987 Chevy R 10 Silverado 2007 Azera 2011 Cadillac CTS Premium Last edited by Harley03joe; 03-08-2018 at 05:05 AM. Reason: Pictures |
03-08-2018, 08:59 AM | #13 |
Re: Cross Member
Harley if you do the photobucket hotlink fix you can see all the picts, here is the link for google chrome, there are other links for different browsers,
https://chrome.google.com/webstore/d...bifiaedg?hl=en can't tell if its the right link because i already fixed mine, but all you have to do is search photobucket fix if you don't see the fix link |
03-16-2018, 03:39 AM | #14 | |
Re: Cross Member
Cut The Lip Off The Trans Cross Member So I Can Put My Deep Aluminum. Trans Pan Up On It
