Old 10-21-2018, 07:12 PM   #1
72 k15
72 k15's Avatar
72 Gmc k15 Lift adivice
Gonna need a small lift on my 72 k15 danna 44 front 12 bolt rear going to convert to a 4spd, putting 33s on will the 3.07 and the granny low gear be enough to take off with 33s?, Looking for a small 2-2.5" lift to fit the tires and get some ground Clearance will be driven as a daily so hoping for a good ride.
72 k15 is online now   Reply With Quote
Old 10-21-2018, 07:28 PM   #2
sweetk30
sweetk30's Avatar
Re: 72 Gmc k15 Lift adivice
i had 4.10 gears and 4 speed . never used 1st much with even 35" tires . but jumped up to 38" tires and had to start more in 1st gear .
so short answer you prob wont notice much . .
look at tuff country suspension lifts for a good off the shelf ride .
ruff country ride just like there name . i wont even deal with them .
these people are SUPER quality service . http://www.offroaddesign.com/catalog.htm
and as to shocks lots of guys are going bilsten shocks for the best leaf spring ride and shock combo .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-21-2018, 08:12 PM   #3
72 k15
72 k15's Avatar
Thinking ill go with the tuff country 2" should clear 33s, I am going to need to do some highway driving to get the play spots so I am wondering is 3.07 gears will work with 33s would I have to use the granny to get going?
Old 10-21-2018, 08:26 PM   #4
Mike C
Mike C's Avatar
The real issue is fuel economy on the highway. My experience with big tires and no gear was crappy mileage because you were below the efficient operating range of the carbureted motor setup. I would start saving for a gear swap. 3.73 with 33" tires or 4.10 with 35's. My 4.10's are the perfect gear for the 35" BFG AT's on my truck.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-21-2018, 08:43 PM   #5
72 k15
72 k15's Avatar
The problem with upgearing is,rpm ill be at 3000rpm at that point on the highway and need to swap in a nv4500 (2000$) at least plus gearing... Will be putting in a TBI unit as ND is cold as hell my 02 sierra 5.3 starts in -40 easy unplugged.
Old 10-21-2018, 09:12 PM   #6
My '90 Blazer had 4spd, 3.08s, and 33/12.50s for most of it's life. It did fine. Yeah, it was a lunge starting off in 2nd, but that thing rolled on out. Never missed O/D in that thing. On a real steep take-off I'd use 1st. With 3.08s it wasn't ridiculously slow. It yanked right out, but the shift came quick.
Old 10-22-2018, 10:37 AM   #7
sweetk30
sweetk30's Avatar
70 mph with 33.0 tall tire
3.08 = 2200
3.42 = 2440
3.73 = 2660
4.10 = 2920
Old 10-22-2018, 02:41 PM   #8
72 k15
72 k15's Avatar
3.08 = 2200
3.42 = 2440
3.73 = 2660
4.10 = 2920
Speed limit here is 75 the flow is about 80-85 I think im going to 3.73s and swap in a nv4500 anyone here done that?
Old 10-22-2018, 07:33 PM   #9
sweetk30
sweetk30's Avatar
that be a good combo .
lots and lots of nv4500 swaps out there done .
nv4500 swap with 33.0 tire @ 75mph
3.08 = 2350 4th / 1760 5th o/d
3.42 = 2610 4th / 1960 5th o/d
3.73 = 2850 4th / 2130 5th o/d
4.10 = 3130 4th / 2350 5th o/d
here ya go play more if you want . every box can be changed for speed / feet / mph distance . huge drop down window for trans options . http://www.grimmjeeper.com/gears.html
Old 10-22-2018, 07:54 PM   #10
72 k15
72 k15's Avatar
Would it be worth it going with 4.10s or just keep 3.73s with that overdrive,cool website haven't found one that useful in a while. Have a thread on a nv4500 swap?
Old 10-23-2018, 11:15 AM   #11
sweetk30
sweetk30's Avatar
the way i would do it is put your cruising rpm in the middle of the power band of the engine so your not working it hard .
and check to see what the carrier split is for each axle so you can price out gear swap parts . you might need new carriers for the jump to 4.10 gear .
most of the time its cheeper to go used axles with the gear you want than install all new in both unless you can setup gears your self .
Old 10-24-2018, 07:22 PM   #12
Mike C
Mike C's Avatar
I know you can get thick gears for the 12 bolt so no need to change carrier. I have not seen those for a Dana, but a stripped open carrier for 3.90 and up gears in the 44 shouldn't be more than $100.
Another thing you can do is look for a 3/4 ton 4x4 Suburban donor. I have bought a couple and swapped the better geared 8 lug axles into not only my Jimmy but my kids project truck as well. The '86 had 4.10 gears that I swapped into my truck keeping my Dana 44 front but using the outers from the 10 bolt since I already had 4.10 in it.
On my kids, the '84 donor had 3.73 and we did swap in the 10 bolt front since his truck had 3.07 as well. I paid $300 for one of them and $200 for the other. Although I haven't had much luck finding cheap donors recently.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 10-24-2018, 07:41 PM   #13
72 k15
72 k15's Avatar
Ill most likely just re gear the axles to 3.73 to keep it stock rear has a stock post should I go locket or post front? any good brands yukon?
Old 10-30-2018, 04:27 PM   #14
72 k15
72 k15's Avatar
Anyone know how to do the nv4500 swap?
