11-23-2018, 12:25 PM | #1 |
Do you run ethanol free gasoline?
I have a crate engine so I run ethanol free but I would think new engines (or rebuilt) being sold could handle the ethanol. I also run mid-grade and I am always wondering if I need a lead additive? I have read what we should do per say but am more curious on what people are doing.
11-23-2018, 01:01 PM | #2 |
Re: Do you run ethanol free gasoline?
I started to because it is easily available from home and figured it would be better for the carb. Mine also runs much better on it
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
11-23-2018, 01:06 PM | #3 |
Ethanol free isn't even an option near me and we are sitting near the source of much of the fuel production.
No need to step up to mid grade unless your engine is 10:1 or more compression and iron heads. Lead additives would be another waste of money. Ethanol is really only a problem with fuel that sits for long periods. Absorbing humidity from the air the fuel can phase separate the water logged ethanol.
11-23-2018, 01:15 PM | #4 |
Nothing wrong with ethanol once it gets to the engine, but it's the fuel system that takes a beating. In addition to absorbing water and potentially causing corrosion, it eats rubber. Last vehicle I touched I re-did the entire fuel system in stainless and braided teflon, without an inch of rubber in the car.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
11-23-2018, 02:29 PM | #5 | |
All about them K’s
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
11-23-2018, 04:15 PM | #6 |
Copy that on the rubber, thank you!
11-23-2018, 04:28 PM | #7 |
I have always known about the impact on seal and gaskets so.
11-23-2018, 05:06 PM | #8 | |
11-23-2018, 09:45 PM | #9 |
There is just ethanol gas around here. I use the regular grade for my daily driver. I have had no problems with the rubber hose I got from LMC and the Quadrajet I got from National Carburetors and the Delphi fuel pump I got from Autozone.
Locking Stant fuel cap did not last, rotted in 2 months. I contacted Stant and they don't think it's a problem, and they don't know what ethanol is or that it could be a problem for the rubber they use. They were happy to loose me as a customer rather than think or talk about it any more. I found another brand that works, and unfortunately lost track of what brand and part number it was. So it depends on what parts you gather together to work, how long they will happen to last with ethanol. A certain amount of trial and error is needed to figure it out. |
11-23-2018, 09:56 PM | #10 |
Yes I do, in everything with a carburetor.
4 bucks a gallon. ..Sucks |
11-23-2018, 11:31 PM | #11 |
This^^^^^^
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense |
11-23-2018, 11:31 PM | #12 |
Junior Member
We're fortunate here around Huntsville there are still half dozen or so stations that have real gas. Some only one grade, but at least it's available. Costs 30-70 cents more than the subsidized 10% corn fuel. I use it in everything including the late model daily drivers, but I especially like it for the vehicles that only get one or two fillups a year. Never have a problem with stale gas and have never had a fuel line or pump go bad.
11-24-2018, 12:38 AM | #13 |
It’s all I run in things around the house- mower, pressure washer, etc. and in my vehicles that aren’t driven lots. It is expensive, partly because it’s high octane too though. I have spent way too much time and money dealing with the panther piss corn juice and the havoc created by it sitting overwinter in the system so it’s way worth it to me. Wish it were more available and in different grades. I really don’t think my 7.5:1 compression ratio mower Needs 93 octane...
1951 GMC 250 Open Express Pickup 1968 Suburban C10 1971 C20 Olive “People are shocked when they find out I’m not a good electrician” Dad told me “Son, never strike a man in anger- unless you’re certain you can get away with it” |
11-24-2018, 10:31 AM | #14 |
We have it here in northern Arizona. 87 octane. I run it in my vintage vehicles with an octane booster. Seems to be OK. I have been told that Sta-bil is a good additive if running 10% ethanol fuels.
11-24-2018, 11:00 AM | #15 |
Wow. I thought NY was bad. Non ethanol high test is 3.19 around me. I use it in all my power equipment and older cars and motorcycles. Since they tend to sit more than my newer everyday cars. Or should I say car my truck is diesel
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
11-24-2018, 11:00 AM | #16 |
Startron is the better fuel life extender, IMO. We have no real gas in my area, only 90% gas/10% trouble. I run it in everything. I haven't had issues from over winter sitting and most of the time I never get around to adding Startron. I put that in my gas and mix cans, even though the mix oil has extender. Ethanol issues have snuck up on my stuff a few times. It's always when I let something sit unused a little too long. When I'm using my chainsaw a lot I use pump gas, like during winter. The rest of the time that and my weedeater get the canned 50:1 pure fuel. I just had to fix my saw again from sitting, so from now on it's the canned pure or fill the can at one of the two places I know sell ethanol-free. Both about an hour away. My truck I go out and start every few weeks and so far so good
11-24-2018, 12:24 PM | #17 |
My vapor locking in traffic absolutely stopped when I found a station with E- free gas.
These carbed trucks where designed to use GASOLINE. The main bummer is finding stations that carry E - free fuel. All the Best, Dirk |
11-24-2018, 03:41 PM | #18 |
I wish they would quit messing around with this E10/E15 BS and go straight to E85 - at least I could then build an engine to take advantage of the increased octane rating.
11-24-2018, 04:13 PM | #19 |
or you could try to build one that works with regular fuel ? Why does everyone blame the fuel rather than the builder ?
oh it's the fuels fault . I did everything right but the fuel is the problem ... whaaa whaaa
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
11-24-2018, 06:10 PM | #20 |
Ethanol is abundant because of the Corn(farmers) lobbyist. I do not run it in any of my old vehicles.
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
11-24-2018, 08:59 PM | #21 | |
If this was directed at me, I am not blaming anyone. All of my carbureted gas engines run great on 87 octane E10. My point is, if we had 100+ octane E85, you could up the compression ratio and change the cam and/or even add some boost to take advantage of the added octane rating and make more power. |
11-24-2018, 09:16 PM | #22 |
As may others have said, I only run ethanol free in my carbureted engines. My C10, CJ5, and all lawn equipment. I don't worry one bit if I leave one sitting without starting it up for a few weeks.
06-26-2019, 09:54 PM | #23 |
I run ethanol free fuel in all my carbureted and small engines.
Last Friday I hooked a trailer loaded with a mini excavator to my Longhorn and headed east 45 miles to help my BIL with a flipper house he bought. I was running late and had no ethanol free fuel on that side of town, so I filled up with 10% ethanol. On the morning trip, it was cool, and the old truck was running great. On the return trip the temp's were in the nineties. In the long pulls, the truck started to vapor lock. I have about a mile of uphill pull to the shop, and I got about 150 feet from the gate when it completely quit. I let it cool for 10 minutes and it ran enough to get me in the gate. I have two big blocks that will vapor lock when running ethanol in hot weather.
06-26-2019, 10:14 PM | #24 |
Carpe manana
We have 91 octane ethanol free at most stations here and one station that has pumps with both 89 and 91 octane ethanol free.
06-26-2019, 10:26 PM | #25 |
Who Changed This?
I have an electric fuel pump to feed the mechanical fuel pump on the engine. The electric fuel pump was installed by my FiL because of the running-out-of-fuel issue when switching tanks. The truck could use a gauge that reads each tank, instead of watching the odometer. I see that those were available. Gonna have to look around for that.
