Old 03-06-2019, 07:51 PM   #1
19SIKtySix
19SIKtySix's Avatar
Transmission Lines
Just wondering if anybody has used the Russell Twist Lok hose/fittings for transmission cooler lines?
Chuck
Instagram: c_lo_garage
Check out my 1966 C10 project "El Viejito" here:
http://67-72chevytrucks.com/vboard/s...d.php?t=674614
19SIKtySix is offline   Reply With Quote
Old 03-06-2019, 11:37 PM   #2
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: Transmission Lines
I'm running the aeroquip push lock stuff and summit ends between hard line and cooler lines. Also using same combo for the low pressure fuel system
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 03-07-2019, 02:35 AM   #3
First c10
First c10's Avatar
I ran Russell power flex. Pretty cool stuff.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-07-2019, 01:55 PM   #4
skyphix
Subscribing and tacking on to this thread - Seems like the Russell Powerflex is the way to go - what ends were used to connect to the radiator/factory cooler and the trans end?
Going to be running a 4L80E but should be the same connectors as the 4L60E I believe.
EDIT: Did some digging and found this:
Converts the 4L80E stock fittings to -6an fitting - which if I understand correctly means I'll be able to just run standard high pressure braided line suitable for trans fluid to the compression fittings at the radiator/stock cooler end. Radiator/stock cooler is from a 2006 Yukon that was originally equipped with a 4L60E
http://www.purechoicemotorsports.com...rod/prd338.htm
Eric
1980 C10 SWB
2003 Chevy Suburban 2500 LT
skyphix is offline   Reply With Quote
Old 03-07-2019, 02:36 PM   #5
First c10
First c10's Avatar
I removed the stock fitting on my transmission and install a fitting that went from the transmission case to a -6an fitting.
https://rover.ebay.com/rover/0/0/0?m...2F132719580276
GO GO!!!
Old 03-07-2019, 03:16 PM   #6
19SIKtySix
19SIKtySix's Avatar
I recently purchased the Russell adapters from transmission fitting to -6an and also purchased adapters to -6an from my radiator.
I already have the twist-lok lines and fittings for my fuel system, I just wasn't sure if it was able to be used for transmission cooling as well.
When assembling my fuel system, I had no problem putting the line on the fittings, they are double barbed and you have to push like crazy to install. I have no worries about these coming lose, plus it was real quick to put together.
Chuck
Old 03-07-2019, 06:21 PM   #7
skyphix
Ah, looks like that line is rated to 250psi and is oil safe, which should be plenty for trans cooler lines, and I am sure the ends would be fine too - the cooler lines on my Toyota (with similar pressures as a GM OD Trans) uses fuel injection rated clamps at the cooler end and oil-safe fuel injection hose... been great for 2+ years and 50,000 miles.
Eric
1980 C10 SWB
