06-15-2019, 03:33 PM | #1 |
At the body shop.
Multi function switch
I have a 99 OBS Crew cab needs a new switch, watched a few videos read a bunch.
Do you need to pull the steering wheel for a no air bag column?
" That didnt make it any newer " " Dont antique the equipment " |
06-15-2019, 05:54 PM | #2 |
At the body shop.
Re: Multi function switch
Nope dont need to pull the wheel off or the upper plastic column cover. #25 torx bit and a 1/4" end wrench.
And a 4mm socket will work on the invert torx head on the lower cover. Brittle parts though go slow
06-17-2019, 08:24 AM | #3 |
Questionable
I am needing to replace mine also, '98, airbag.
Found a YouTube video that showed how to replace it without disabling SRS or taking off the wheel, just remove the two halves of the clamshell. For the life of me, I cannot find the video anymore and it's pissing me off. I've had the replacement part for weeks now. All the videos from 1aa auto (or whatever) on YouTube all show removing the wheel and disabling SRS.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
06-17-2019, 09:27 AM | #4 |
At the body shop.
Not sure what differences between the two columns. But I didn't even pull the key tumbler. Left the top half of the clam in place.
Now my wipers work correctly too.
06-20-2019, 11:06 AM | #5 |
Good info so Thanks for sharing!
Where are you guys sourcing the replacement Multi Function Switch?
06-20-2019, 02:38 PM | #6 | |
Questionable
I had a bunch of credit on eBay/PayPal before they split. My Hazard switch has been stiff as hell for a while, I think a PO spilled something in it. I know there's a replacement kit for just the hazard bit, but the white text is wearing off my stalk, so I figured I'd replace the whole thing, clean it up, re-sell for $20-30 or something. "Standard" brand has a pretty good reputation on their parts, very similar (or maybe the source) to Dorman, so I picked up theirs, p/n: DS698T https://www.ebay.com/itm/400669584334 I got mine from eBay, but during a price drop from that seller. I think I got out the door for around $50, which was $5 cheaper than the one currently eligible for Amazon Prime, and about $30 cheaper than my big-box store with a 10% coupon. There's a
06-20-2019, 05:58 PM | #7 |
At the body shop.
GM one from Amazon $200 ish
Check this out at Amazon.com ACDelco D826A GM Original Equipment Turn Signal, Headlight Dimmer, Windshield Wiper and Washer Switch with Lever https://www.amazon.com/dp/B000C9MN90..._hiadDbJ7T0MVK
06-21-2019, 09:29 AM | #8 | |
Questionable
06-21-2019, 10:19 AM | #9 |
At the body shop.
$200 is a cheap price to pay too not do it a 2nd time.
