Old 10-12-2020, 11:20 PM   #1
Ziegelsteinfaust
Dirt Every Day
The other day I watched the Dirt Every Day episode where the cut the roof off a F250, and lifted it. I was kind of digging on it. Not enough to do it, but it still got me thinking.
Obviously they have tv budgets, and time frames to work with.
But let's say I was to recreate the project. Is there any disadvantage to shortening the body, and welding the bed to the cab portion? Think a F250 version of a CJ8?
I am fairly new to 4x4's. Currently I have a 1/2 finished Willy's wagon that I will work on when I take a weeks vaca in December. Plus I had a K20, but I only explored dirt roads with it.
Ziegelsteinfaust is offline   Reply With Quote
Old 10-13-2020, 07:45 PM   #2
Mike C
Mike C's Avatar
Re: Dirt Every Day
Ford made Uni-Body trucks in the early 60's. Google for images. Anything possible with a welder and a saw!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-13-2020, 10:11 PM   #3
Zoomad75
K5Camper
Zoomad75's Avatar
Re: Dirt Every Day
GM already did that. They are called Blazers and Jimmys. Short body, check. Bedsides connected to the cab, check.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 10-14-2020, 01:55 PM   #4
1976gmc20
Re: Dirt Every Day
Full size Bronco with 3/4 ton axles ?????
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 10-18-2020, 12:00 PM   #5
Re: Dirt Every Day
Yes, your idea makes sense. I'd like to make my own Blazer using a long bed 67-72. Use a Blazer frame (any year) or shorten the long bed frame. Cut out a square with the wheel opening in it. Cut cab just behind door jamb/cut front of bedside to weld up. Bob rear as desired, measure forward on bedside to cut to length, them get wheel opening into proper place. I think I'd cut the top once the bed and cab were unitized. I wish I had a picture. Saw a 2wd Blazer made that way showing all the cuts. But that one had no doors. Just the bedside running to the front fender. You just climb in.
Old 11-24-2020, 06:28 PM   #6
CG
BlahBlahBlah
Re: Dirt Every Day
This one?
Old 11-25-2020, 05:21 PM   #7
Ziegelsteinfaust
Re: Dirt Every Day
That is pretty sweet though.
Makes me wonder how practical that roadster is work on or fix.
Old 11-26-2020, 11:02 AM   #8
Re: Dirt Every Day
Originally Posted by CG View Post
This one?
Yep! A 4wd would need a tailgate up through the middle entry. I'd like to do one low like this one. Just a box with wheels. I guess the beach bum in me wants it
