LS1 into a 73 cheyenne
I'm in the process of doing a swap. Ls1 from a 98 Camaro into a 1973 Chevy truck s/wheelbase.
Engine: LS1 from 98 Camaro, modified with LS6 heads, LS6 intake manifold, 5 pin mass air flow, twin horn air intake. comp cams kit LSR 281-289 113. Headers from Street & Performance. Taylor 10.4mm ignition wires. Full set of billet pullys No heater or A/C unit Transmition: 4L60E ford 9" Strage center section with 4.11 gears Rear suspension : 4 link from ridetech with ridetech adj. coilovers Exhaust: dual, headers from Street & Performance 2 1/2" collectors, Hooker aero chamber mufflers, on 2 1/2" pipes, stainless tips from Cherry Bomb Radiator: Griffin aluminum with trans cooler, in/out water lines on passenger side. Trans cooler lines on driver side. Gas Tank: I will be running only 1 16 gallon tank from a 87 with in tank fuel pump, reason for upgrade is for the in tank baffles so the engine wont starv. Gauges: Autometer Harness: stock harness and computer, modified harness and re-tuned computer Brakes:2010 C6 Corvette style front- 14" 6 piston rear-13.5" 4 piston - master cylinder from Wilwood note: may encounter vaccum issues due to cam and massive breaks, if so i will run an electric vaccum canister More to follow..... Last edited by smokedat; 12-21-2010 at 01:56 AM. |
Re: LS1 into a 73 cheyenne
pics
exhaust
some more pics
Very nice.
Jay 1978 Big 10 Silverado, 355 + 700R4 + 3.42 + factory tach + A/C + dual tanks + working cruise control = awesome highway cruiser. |
Future: 86 on GenIV power!
![]() Join Date: Jun 2009
X 2................nice
awesome
Project Optimus Prime
84 SWB work in progress ![]() ![]() 89 burb 1500 (parts pig) LOL ![]() 08 ford focus (I know, I know) Wifes car ![]() "I said it b4 and i'll say it agian wiring is my worst enemy":devil: ![]() |
that is awesome!!
![]() what fans are you going with? and how many miles are on the motor/trans? the heads look like they've been gone through and cleaned up. SWEET!! looking forward to updates!!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
epicccccc..
very nice photog skills my friend. cant wait to see this together |
Awesome project. It's going to be badass when done
1973 custom delux 20 with 454 project 2000 dodge neon |
Lookin good!
another subscribed thread
Any recommendations on the electric fan? i think I'm gonna go with the Jegs single 16" S-Blade 2200 CFM puller. The engine and tranny had 70K+ miles.
#15 |
LS1 Swap to a 73 cheyenne
deleted double post
#16 |
i'm planning on the same radiator... but i gotta look into this. http://hotrodlane.cc/77chevytruck/77chevy.htm
apparently you can order the fans to go with the radiator. btw, (if you dont mind) how much did the radiator alone set ya back? here's a couple more options too... http://bertok.us/agreif/fans/fanstech.htm http://www.chevytalk.org/fusionbb/sh...hp?tid/194489/
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() Last edited by menace121978; 12-10-2009 at 02:43 PM. |
#17 |
oh yea, the intake runners sure look clean for 70k!
#18 |
Re: LS1 Swap to a 73 cheyenne
deleted double post
#19 |
deleted double post
#20 |
deleted double post
#21 |
Those are not 98 model heads 97&98 LS1s had perimeter bolt valve covers VS the center bolts on the 99 & up
#22 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Gonna be sick. Cant wait to start a LSX swap of my own.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#23 |
great start cant wait to see it finished
77 CHEVY - SHORT BED STEP SIDE 2WD 02 CHEVY - EXT CAB SHORT BED Z71 7 INCHES OF LIFT |
#25 |
There not LS6 heads either. LS6 heads have a 243 casting number. It looks like 799 on these or 79somthing
Tags |
73c10, c10, cheyenne, ls1, swap |
