Old 05-12-2012, 09:19 AM   #1
scotts62
One day...
scotts62's Avatar
Talking What did you do to your truck today??
Seems to be a lot of questions which is fine but did anyone add anything or do anything to their truck today?? If so what did ya do? Oh and pics make it all better
(Couple days ago)
I got closer to getting this thing running, fixed some wiring, swapped out torque converter for new one (new trans old converter, i knew better) modded trans mount to fit 4l60 (had bb and 4l80) Installed exhaust, driveline, finished up the front suspension swap to 5 lug and all new calipers, rotors, hoses and bearings
Scott
93 crew cab build
Project 62
Old 05-12-2012, 09:57 AM   #2
project 67 sub
project 67 sub's Avatar
Re: What did you do yo your truck today??
nothing.... its sitting back at the company yard/terminal in so cal, and im in texas (im an OTR truck driver). but when i get back its gonna be needing a motor put in it
project 67 sub is offline   Reply With Quote
Old 05-12-2012, 12:38 PM   #3
70stroker
70stroker's Avatar
I started my 6 inch lift install. got the back done so far.
1
70stroker is offline   Reply With Quote
Old 05-12-2012, 09:07 PM   #4
benoit454
Chris
benoit454's Avatar
tore my front end apart for a rebuild.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 05-13-2012, 06:14 PM   #5
benoit454
Chris
benoit454's Avatar
pic proof on the front end..
Chris
GIT R DONE!!!!!!
Old 05-14-2012, 03:54 PM   #6
75ChevyGuy
GM Parts Guy
75ChevyGuy's Avatar
I put a "new to me" center console in it from the swap meet. Tonight I'll be putting in my open element air cleaner.
1975 Chevrolet C-10 Custom Deluxe (DD/WIP)
1989 Chevrolet C1500 reg cab stepside (Winter Truck)
1977 Harley Davidson XLH 1000 (Summer Cruiser)
75ChevyGuy is offline   Reply With Quote
Old 05-16-2012, 07:04 AM   #7
scotts62
One day...
scotts62's Avatar
Fired up the crew cab and let it take its first breath of air, sounded good so far!
Scott
93 crew cab build
Project 62
Old 05-16-2012, 07:58 PM   #8
cflvulcan
cflvulcan's Avatar
cool, i drive truck too, northeast region tho.
But today i had the day off and played with my 97 sierra. I rewired my headlights so now when the highbeams are on, all four lights light up. And i put on a led 3rd brake light ive had sitting around for a year or so lol.
cflvulcan is offline   Reply With Quote
Old 05-17-2012, 06:12 AM   #9
speedygonzales
speedygonzales's Avatar
Took the bed off to replace the fuel pump module and did a rust conversion and chassis paint job while I was there.
99 Z71 (98 body style)
Pride and joy
speedygonzales is offline   Reply With Quote
Old 05-19-2012, 04:08 AM   #10
TecRsq
TecRsq's Avatar
Purchased a turn key, low mileage 5.7 / 4L60E combo to replace the tired 5.7 TBI / 700R4 drivetrain.
TecRsq
_____________
1986 Chevy K30 3+3, 454, SM465, NP205, D60 , 14 Bolt, CM Industries SS Flatbed, ORD 6" suspension, 9.00 x 16 Michelin XML'S
TecRsq is offline   Reply With Quote
Old 05-19-2012, 05:09 AM   #11
project 67 sub
haha sweet. yah i run 48 states and canada, so i go where ever they send me....
Old 05-27-2012, 01:38 PM   #12
scotts62
One day...
scotts62's Avatar
Ripped apart a parts truck so i can split the parts between the X and crew cabs.
pulled the bed off the crew to use new bed and rear section of the frame.
Scott
93 crew cab build
Project 62
Old 05-28-2012, 11:17 AM   #13
Boog
laying low
Boog's Avatar
Scott I wish I knew you were needing the rear half of frame and short bed for the crew. I have just what you need, in great shape too from my wrecked 97 GMC.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-04-2012, 11:22 PM   #14
scotts62
One day...
scotts62's Avatar
Well i scored the parts truck and then decided to use the rear half of the frame as i was thinking of what all i could use off of it. Even got it off and going to try and get it grafted tomorrow but we will see..
Scott
93 crew cab build
Project 62
Old 06-05-2012, 11:37 AM   #15
benoit454
Chris
benoit454's Avatar
right now I'm working on my body work underhood. I got the inner fenders done yesterday and the bottom wheel side of them painted, same as the frame and susp. up front. The top side has been primed, waiting on the bottom to dry up today then hopefully wetsand and paint the top engine side tomorrow.
I'll post pics later.
Chris
GIT R DONE!!!!!!
Old 06-05-2012, 08:31 PM   #16
MaritimeDragRacing
MaritimeDragRacing's Avatar
Spent almost 200 hours working on my 1994 Cheyenne in my gravel driveway just on the fine weather days since mid March. Rains a lot here so sunny days were 10-12 hours of work.
PARTS
2 new tires(10.5X31X15)
2 perfect doors from parts truck(with mirrors)
4 door pins, bushings and clips
1 fender from parts truck(repaired)
1 rear wheel tub from parts truck
2 cab corners(inner)
2 cab corners(outer)
2 rocker panels(inner)
2 rocker panels(outer)
2 patches in floor(one sq ft)
3 cab mounts(from GM dealer)
2 sway bar end links
4 shock absorbers(and bolts)
1 front caliper
1 set of brake pads(front)
3 brake lines
1 bleeder screw
1 ball joint(upper)
1 dome light switch
MATERIAL
4 cans weld-through primer
5 cans Tremclad(flat black)
2 rolls MIG wire(2lbs each)
4 zip cut discs
2 cans rocker guard
2 cans undercoating
http://www.maritimedragracing.com
Atlantic Canada’s #1 source for Drag Racing News, Race Results, Schedules and Track Information.
MaritimeDragRacing is offline   Reply With Quote
Old 06-05-2012, 10:25 PM   #17
project 67 sub
left it still sitting in the parking lot at work back in cali (im in kentucky right now) so its still waiting for me to get back so i can do the motor build (finish) and swap it all in a period of 6 days along with a bunch of other crap....
Old 06-05-2012, 10:32 PM   #18
benoit454
Chris
benoit454's Avatar
pics of what I did today...
Chris
GIT R DONE!!!!!!
Old 06-07-2012, 09:54 PM   #19
benoit454
Chris
benoit454's Avatar
wow how did I miss yesterday?
well heres today..
Chris
GIT R DONE!!!!!!
Old 06-07-2012, 09:58 PM   #20
benoit454
Chris
benoit454's Avatar
now for yesterday big update....
yes as you can see removed both fenders, inners were already removed, finished smoothing the backside, then pirmed them.
I also threw down some paint on the inners, same as today on the hinges and such.
Chris
GIT R DONE!!!!!!
Old 06-10-2012, 08:16 PM   #21
jsm110
jsm110's Avatar
Nice! looking forward to seeing how you did the firewall and seeing it finished
Jacob
1993 c1500
jsm110 is offline   Reply With Quote
Old 06-10-2012, 10:02 PM   #22
benoit454
Chris
benoit454's Avatar
glad you posted cuz I got more pics...
couple pics of the flake
d you
Chris
GIT R DONE!!!!!!
Old 06-10-2012, 11:12 PM   #23
jsm110
jsm110's Avatar
Looks great. definitely gotta consider doing that to my truck now. was it hard to mask everything off?
Jacob
1993 c1500
Old 06-11-2012, 10:49 AM   #24
benoit454
Chris
benoit454's Avatar
nope you see how masking it is, a rug/throw over the motor, and some tape on the radiator sides then on some hoses and cables and such, only until they fell under the cover, then I did nothing else to them.
Here's the kicker, that's spray cans, so less over spray and easy to get in and use in tight spots.
It was around the same price if not cheaper then using quarts and such.
before anyone gets any ideas, this IS auto paint, it was mixed at the body shop supply, and it's single stage with hardner just as you'd spray from your paint gun so yea it'll last and it'll hold up great.
I bought 5 cans, used 4, $17 a can(some were cheaper for some reason, like when I bought more then one thing) so I got roughly $60-70 in what I done, not counting primer and filler, or sand paper, primer was spray cans, used 3 kinds, all rustoleum brand, used self etch on bare metal, filler primer on body work areas, then used some black on the firewall, made my paint cover better and faster being dark.
Now quarts and such run you roughly $50 a quart or more, then you add in reducer, which in my case for the base coat I got to use on the outside of the truck is $10 a thing, then hardner is usually $25-50 a pint can, so yea it costs more that way, plus everything and I mean EVERYTHING! has to be masked off due to overspray.
I should have masked more, I got some on the window and front chrome, but hey thinner brings that off easy. I'll just touch up my frame with some black and that'll fix it.
Chris
GIT R DONE!!!!!!
Old 06-11-2012, 11:34 AM   #25
jsm110
jsm110's Avatar
Thanks for the run down. looking forward to doing this myself now. definitely want to see it when youre all done
Jacob
1993 c1500
