08-24-2014, 09:58 AM | #26 | |
Cluster King
Re: 67-72 Chevy Truck fuel gauge diagnostics 101
Thank you. We are just trying to help these guys/gals find and isolate a problem with the fuel gauge/sender to prevent just changing parts and not getting an expected result. My hope is that this (with the help of Vette) will help diagnose problems that are often very simple to repair as long as you know how to test them for function. If I have never said it, Vette, I appreciate you sir for adding your knowledge to this thread. I will soon do a separate thread for temp gauge diagnostics as they are often brought up in discussion on this forum. Have a good Sunday, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
08-24-2014, 10:04 AM | #27 | |
Cluster King
keep us posted on what you find out. Take care, Tom
08-24-2014, 10:44 AM | #28 |
I went and tested the gauge.When I pull the brown wire from the fuse block the gauge reads just past the last "L" in full. Not 3 oclock.
When I ground the fuse block connection it goes to empty. When I turn the key off it slowly creeps back up. Sender is reading 10 ohms. I did test a spare gauge and it reads 38 ohms left pole to right pole. (just for reference) So would the next step be to measure the gauge in the truck? Think I will try that while waiting for response. Thank You fellas for all you do.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 Last edited by jjzepplin; 08-25-2014 at 07:02 AM. |
08-24-2014, 10:58 AM | #29 | |
Cluster King
That is strange and would make me think there is something wrong wiith the gauge resistor or the gauge itself. "Sender is reading 10 ohms." You are referring to sending unit in the tank, correct? If it is accurate, I would believe you have or should have almost an 1/8 of a tank of fuel. "I did test a spare gauge and it reads 38 ohms left pole to right pole. (just for reference)" Did you do this to the gauge in the dash as well? If not, try it but unplug the connector from the cluster so there is no back feed. Sorry but I have to log off and get to the Airport for El Paso. I will check back on this soon. We are going to figure this out and get your gauge working properly Take care, Tom
08-24-2014, 11:10 AM | #30 |
I get 66 ohms left to right pole when big harness plug is removed.
87 ohms right to middle and 74 ohms left to middle.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 Last edited by jjzepplin; 08-24-2014 at 11:18 AM. |
08-24-2014, 11:56 AM | #31 |
Is this the resistor?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
08-24-2014, 12:54 PM | #32 |
Cluster King
Yes, that is the resistor. There should be a brown colored insulator that goes behind it.
The ohm reading you posted don't look right to me. I am not at my shop or I would test a few that I have in my inventory. As it sets, the resistor should show a reading of around 100 ohms. That is if it is loose from the gauge.
08-24-2014, 02:58 PM | #33 |
It shows 88 ohms when removed. This is the test gauge though.
I have three fuel gauges and all test with different values-boo! The closest to your original post is the test unit this resistor is from. I am thinking my gauge is screwed up and my sender is bum as well.
08-24-2014, 04:17 PM | #34 |
Great write up!! Could have used this a couple months back.
Justin 67 C10 LWB Fleetside "Bessie" |
08-24-2014, 05:41 PM | #35 | |
Cluster King
Keep us posted, Tom
08-24-2014, 10:53 PM | #36 |
Sent you a PM.
Bob 1967 2wd Burb, 350/TH350, 3.73 posi |
08-28-2014, 07:55 PM | #37 |
Well I guess I am going to have to pull the monster 35 gallon tank out. Sum b--ch! I will pump out the remaining fuel with an electric pump and test the sender. I think it is an Aero tech tank. Anyone know where to find a sender if I need one?
08-30-2014, 03:57 PM | #38 |
Cluster King
I just checked 43 of these resistors I have in my inventory and I get between 96 and 108 ohms on all of them. These resistors will/should have the same ohm value as the porcelain later style resistors. Also, the color code does not seem to have any difference in the value.
Hope you all are having a good holiday weekend. Take care, Tom
08-30-2014, 04:00 PM | #39 | |
Cluster King
Hey JJ, Any word? Were you unable to check the sender in the tank by filling it up at the gas station while watching the meter? I am curious on how this turns out for you. No clue on where to get a sender for that style of tank but make sure it is a 0 to 90 ohm range. Have a good holiday, Tom
08-30-2014, 06:42 PM | #40 |
I haven't got the balls to do it yet, and won't have time off til Friday.
I will also check the gauge resistor on the truck a the same time. I will also check the cluster going into "No Daggum Money" this way BEFORE I install it.
08-30-2014, 06:47 PM | #41 | |
Cluster King
Have a good holiday Tom
08-30-2014, 06:53 PM | #42 |
You have already been a fantastic resource and I appreciate all you do. I WILL jump in and go for it and get this sucker fixed. It's only been 10 years of no gauge. It was a long drive from Cali to Fl. wondering if I was gonna run out of gas.
11-01-2014, 07:59 PM | #43 |
OK. I installed my 4x4 front sway bar. WHEW- What a mutha! I am about to get back on this gauge. If I need a replacement sender for the Areotach tank.Where would I find one? I think it is the 5 screw type IIRC.
11-01-2014, 08:22 PM | #44 | |
Cluster King
I am not sure about the sender for the aftermarket tanks. You may want to contact the company of the tank. Maybe someone else will chime in or you can post the question in a new thread on the general forum. I have absolutely no experience with these style tanks but I do know that it will have to have a sender with a 0 - 90 ohm range for the factory gauge to work. Hope this helps and good luck. Take care, Tom
11-01-2014, 10:13 PM | #45 |
This is the sender I found. What do you think?
http://www.summitracing.com/parts/sw...P4EaAjJX8P8HAQ
11-02-2014, 12:28 AM | #46 | |
Cluster King
Keep me posted, Tom
11-03-2014, 02:37 PM | #47 |
And the resistance is correct (0 - 90 Ohms). That is VERY important. Looks like it will do the job.
11-06-2014, 05:30 AM | #48 |
Ordered it up. Stay tuned. I will test the gauge prior to installing the sender. Mostly to stall off from pulling the 38 gallon tank. BWAHAHAH! Meanwhile I got my Blazer tub on the frame - UGH. I will use your info to re-pin the harness to a gauge type dash. Hoping to get a tach in that one soon but oh well. I have the outer tin and printed circuit. Kinda like like my Caddy-one piece at a time.
11-08-2014, 02:15 PM | #49 |
OK so I go after this mutha with a vengeance and tested the new sender with my old gauge and boom she works fine. Drop the empty tank and pull the old unit. Then it hits me-new one does not have a pickup for the fuel! Sumbugger! So I modify the old pickup to use the new sender. Took a pencil torch and soldered it on. Tested and boom still working good. Then it hits me-again this whole apparatus needs to fit thru a small arse hole. Aint happenin the way I have it. So rebend the pickup and float and bend this and that and finally it goes in. I think It works as I put 2.5 gallons from a can in it and the needle moved up. I think It may register full for a couple gallons before it registers any movement but it will tell me when it's empty. Full should be at 30 gallons.
11-08-2014, 02:23 PM | #50 | |
Cluster King
Good work JJ, Take care, Tom
