72 Cheyenne K10 SWB Numbers Matching
Was after this truck from the original owner's widow for 16 years. He died in 1989. She drove it a little bit in the winters. It was a farm truck and even had a stock rack for hauling cattle on it. My sons and I are the builders. We have built many cars and trucks together.
Mike 1972 C10 Cheyenne SWB Black Supercharged Project 1972 K10 Cheyenne SWB Copper and White http://67-72chevytrucks.com/vboard/s...d.php?t=654175 1969 Camaro Protouring LS7 T-56 Project |
Re: 72 Cheyenne K10 SWB Numbers Matching
Inside bed picture. The truck had 43,444 original miles on it before the restoration started. Bought it in early October 2013. We only have a month or two in the winters to build them, but were about 7/8 done with it now.
[ATTACH]1340727[/ATTACH
Interior before:
Underside:
Engine Bay:
The truck was bought new in Reno Nevada. They moved to Idaho in 1983. The rust issues we dealt with were the rear cab corners, rear cab mounts, both door bottoms and the hardest one was below the rear sliding glass window. Went to a local junk yard and they ruined a cab for $35.
Getting it torn down:
Mike 1972 C10 Cheyenne SWB Black Supercharged Project 1972 K10 Cheyenne SWB Copper and White http://67-72chevytrucks.com/vboard/s...d.php?t=654175 1969 Camaro Protouring LS7 T-56 Project Last edited by redbaron; 01-27-2016 at 02:39 AM. |
Spid
The truck will be updated and driven daily. It will pull the planes out of the hanger every morning.
Updates include powder coated frame and various other body parts. 4" lift with custom built springs from Alcan. The back set have a little over 4" to prevent rear droop. Also moved the center pin back 1" for better rear wheel to fender lip alignment. Stroked and bored the engine to a 383 ci. Good thing I overhauled the engine, the old steel head gasket were letting water seep into the cylinders from all the sitting around. Used a new stoker crank and rods. Bumped the compression up to 9.2 and install a torquer cam. Also installed Pertonix Igniter II in the distbutor. Building the engines is my favorite part. Install a tach dash from Tom TBONE1964. Installed a tilt steering column Kevin Kevs Classics Retro Sound stereo with blue tooth, Retro sound in dash speaker (they say use the 5x7 for A/C pickups. We did it, but won't again. We'll use the 4x10 next time) Alpine 4" in upper cab corner and 2 Alpine 8" subs with built in amps under the seat. Running the old 15x10 Mickey Thompson Challenger wheels with the M/T Baja MTZ 33x12.5R15 tires.
Engine Parts:
Powder coated frame with Inline tube SS brake and fuel lines. Have had a lot of leaking issues with this set of line. Inline tube has been good to work with, but slow with result. In the past we've never had an issue with their stainless steel lines.
![]() Join Date: May 2003
Nice SWB 4x4 Cheyenne !!!! You don't find those every day, nice find !
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
#15 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Nice! Looking good. Greetings from Montana. I'm on board for the build.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#16 | ||
The pictures will keep coming quick with the short time frame to get it done.
#17 |
American Autowire classic update kit. We usually use these kits in all our builds, including LS and Electronic transmission vehicles. Use their Highway series in hotrods. On the K10 used the AAW Classic Update kit with a non anti diesel original wiring harness on the A/C system.
Mike 1972 C10 Cheyenne SWB Black Supercharged Project 1972 K10 Cheyenne SWB Copper and White http://67-72chevytrucks.com/vboard/s...d.php?t=654175 1969 Camaro Protouring LS7 T-56 Project Last edited by redbaron; 03-25-2016 at 01:27 AM. |
#18 |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
I'll be watching this build. Looks great so far.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
#19 |
Front and Rear Diffs:
#20 |
Bed:
#21 |
Engine Looking Better:
#22 |
Transfer Case with all new seals and gaskets.
It looked great inside. Used old Chevy Red/Orange colored paint which is darker/deeper than regular Chevy Orange like on the engine. Hard to see the difference in the pictures. In person it's easy to see and looks real nice.
Mike 1972 C10 Cheyenne SWB Black Supercharged Project 1972 K10 Cheyenne SWB Copper and White http://67-72chevytrucks.com/vboard/s...d.php?t=654175 1969 Camaro Protouring LS7 T-56 Project Last edited by redbaron; 02-20-2015 at 01:09 AM. |
#23 |
![]() Join Date: Dec 2013
nice truck , ive subscribed to your build , looks killer
#24 |
More Cab Progress:
#25 |
And More Cab:
